Jun 24, 2016 10:34 AM UTC
Dynamically change the Data Change Type
I have a situation where I ordinarily only want to log a data change when there is a change greater than a particular value. But I have a requirement that I capture data more frequently and accurately when triggered into that mode. Is it possible to change the Data Change Type / Threshold via a service from the platform? can it be done on the edge?
Jun 24, 2016 11:52 AM UTC
If you have a subcription on any property Datachange Event this can be done to log the data change on that specific property  , you can get the new
data for that property as var newValue = eventData.newValue;
Old value as var oldValue = eventData.oldValue;
you can check something like
if (newValue > someVal)
// log the values here you can call any service Things['logdata'].Triggerlog()
If you have not and subcription on property Add Subcription on that property and select event as DataChange
Hope this helps
Jun 24, 2016 1:44 PM UTC
Hi, just extending on what Nilesh mentioned you can also do this from the Edge device for this you will need to address the Aspect ​ for that property, e.g.
//Create the property definition with name, description, and baseType
PropertyDefinition property1 = new PropertyDefinition(
  "Property1",
  "Description for Property1",
  BaseTypes.BOOLEAN);
//Create an aspect collection to hold all of the different aspects
AspectCollection aspects = new AspectCollection();
//Add the dataChangeType aspect
aspects.put(Aspects.ASPECT_DATACHANGETYPE,
new StringPrimitive(DataChangeType.NEVER.name()));
//Add the dataChangeThreshold aspect
aspects.put(Aspects.ASPECT_DATACHANGETHRESHOLD, new NumberPrimitive(0.0));
//Set the aspects of the property definition
//Add the property definition to the VirtualThing
For more have a look at the Edge Help Center > Aspects of Properties
