Oct 17, 2018 1:07 PM UTC
Dynamically create, enable, and restart Things in a webservice
I am trying to create a service that pulls a list of properties from a webservice to create multiple Things of the same type.  I am able to create multiple things in the webservice but cannot find a way to refer to the newly created things in the service so that I can enable and restart.
Here is the code I am trying to run:
///  Loops through a JSON object to extract properties for each thing
while (i < json_obj.devices.length)
var params = {
name: json_obj.devices[i].deviceId/* STRING */,
description: json_obj.devices[i].name /* STRING */,
thingTemplateName: 'XXXXXX' /* THINGTEMPLATENAME */
// no return
Resources["EntityServices"].CreateThing(params);
i++;
//Need to enable and restart newly created thing.  Not sure how to reference it
Oct 17, 2018 7:02 PM UTC
The handle is the name you assigned the thing when you created it:
    var params = {
        thingTemplateName: "GenericThing"
    Things["NewThingName"].Enable();
    Things["NewThingName"].Restart();
Here is some helpful info:
https://community.ptc.com/t5/ThingWorx-Code-Examples-Platform/Creating-a-Thing-in-Service-Script/td-p/533427
Oct 17, 2018 1:16 PM UTC
I can think of a couple of different ways:
1. Enable and restart the Things in the same loop where you created them.
2. Create another loop with the same loop parameters you used to create them and enable/restart in that loop.
3. Save the name of the newly created things in an array and pass that array to a function that enables/restarts them
Oct 17, 2018 6:30 PM UTC
I would like to do it in the loop.  Once I create them how do I call the service to enable and restart.  I'm not sure how to get the handle to the newly created thing.
    var params = {
