Edge Java SDK Update multiple properties with writePropertiesVTQ
I try to update multiple thing's properties with writePropertiesVTQ method.
Calling this method I find an error on apllication log
An Invalid Property Value Was Sent To [Random-Integer-Device1 Property: [null]
Thing name, properety name and value type is correct.
I'm setting up name, time, value and quality in ValueCollection and add it in an InfoTable
My code is
InfoTable it = new InfoTable();
NumberPrimitive np = new NumberPrimitive();
np.setValue("1.0");
ValueCollection vc = new ValueCollection();
vc.put("name", new StringPrimitive("propname1"));
vc.put("time", new DatetimePrimitive(new DateTime(new Date().getTime())));
vc.put("value", np);
vc.put("quality", new StringPrimitive(QualityStatus.GOOD.name()));
logger.info("Adding property propName1 with number value 1.0");
it.addRow(vc);
np.setValue("2.0");
vc.put("name", new StringPrimitive("propname2"));
logger.info("Adding property propName2 with number value 2.0");
it.addRow(vc);
client.writePropertiesVTQ(ThingworxEntityTypes.Things, "thingName", it, 10000);
What is wrong? How can I use writePropertiesVTQ? How can I update multiple properties at time with specify device reading time?
Hi @flucciarini , An Invalid Property Value Was Sent To . This error occurs when you have not defined the remote properties on the platform side which you are updating or when they are inaccurately configured on the platform.
Thank you for reply
The entire error message is
So I need to create remote thing and remote properties to use writePropertiesVTQ method?
Things on platform are manage from another develop group and they haven't create remote thing.
How can I update multiple properties at time setting up reading time with java sdk ?
The only method is with remote thing?
Hi @flucciarini ,If you are using a VirtualThing on the edge we generally recommend VirtualThing::setPropertyVTQ() + VirtualThing::updateSubscribedProperties().
BaseClient::writePropertiesVTQ() is invoking the UpdatePropertyValues service on the Thing.
DataShapeDefinition ds = new DataShapeDefinition();
ds.addFieldDefinition(new FieldDefinition(CommonPropertyNames.PROP_NAME, BaseTypes.STRING));
ds.addFieldDefinition(new FieldDefinition(CommonPropertyNames.PROP_TIME, BaseTypes.DATETIME));
ds.addFieldDefinition(new FieldDefinition(CommonPropertyNames.PROP_QUALITY, BaseTypes.STRING));
ds.addFieldDefinition(new FieldDefinition(CommonPropertyNames.PROP_VALUE, BaseTypes.VARIANT));
InfoTable propertyValues = new InfoTable(ds);
ValueCollection row = new ValueCollection();
row.put(CommonPropertyNames.PROP_NAME, new StringPrimitive("p1"));
row.put(CommonPropertyNames.PROP_TIME, new DatetimePrimitive(DateTime.now()));
row.put(CommonPropertyNames.PROP_QUALITY, new StringPrimitive(QualityStatus.GOOD.name()));
row.put(CommonPropertyNames.PROP_VALUE, new StringPrimitive("toto"));
propertyValues.addRow(row);
client.writePropertiesVTQ(ThingworxEntityTypes.Things, "TESTThing", propertyValues, 1000)
In general we define remote thing and property on thingworx side and map them to the edge property.
Defining the property.
@ThingworxPropertyDefinition(name = "Blob_STR", description = "The device humidity",
 baseType = "BLOB",
 aspects = { "dataChangeType:NEVER", "cacheTime:0",
 "isPersistent:FALSE", "isReadOnly:FALSE", "pushType:ALWAYS"})
Sending the property.
String blobData = "AFAFAFAAFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF";
this.setPropertyValue("Blob_STR", new BlobPrimitive(blobData.getBytes()));
super.updateSubscribedProperties(5000);
 Let me know your use case if it is different.
Hi @flucciarini , Regarding the multiple property updates you can follow this .
https://www.ptc.com/en/support/article/CS221424
Hello @flucciarini
If you feel your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
Om Dukiya
