7-Bedrock
June 6, 2024
Edge Micro Server installation problem
During EMS installation on arm device I get the following error
-bash: ./wsems: No such file or directory
below the system information:
Linux imx8mm-icore 5.15.71-legacy-imx8 #18 SMP PREEMPT Mon May 13 12:33:59 CEST 2024 aarch64 aarch64 aarch64 GNU/Linux
here the ems version: Microserver-Linux-arm-hwfpu-openssl-5-5-0-2778
I've already try to follow the article  CS289594 but It didn't work
Someone has solved this issue?
thanks in advanced
7-Bedrock
June 11, 2024
the problem was solved copying all 32bit libraries the ems program needs in /lib
thanks in advanced
Hello, @EB_10109450
Here are the steps to resolve the -bash: ./wsems: No such file or directory error:
Verify File Existence:
ls -l ./wsems
Check File Permissions:
chmod +x ./wsems
Check Architecture Compatibility:
file ./wsems
Check Dependencies:
ldd ./wsems
Check Current Directory:
pwd
cd /path/to/wsems
Check SELinux/AppArmor:
Temporarily disable SELinux:
sudo setenforce 0
If the issue persists, provide the output of these commands for further assistance.
I hope my suggestion is helpful to you.
Best Regard,
Patrick Fritz
7-Bedrock
June 6, 2024
thanks for your quick reply,
the file exists and has the execution permiss.
the command ldd ./wsems return an error:
not a dynamic executable
Emiliano
Rocko
You can try to run strace wsems to further investigate. Most probably a 32/64 bit issue or a missing library.
For reference: https://unix.stackexchange.com/questions/75054/ldd-tells-me-my-app-is-not-a-dynamic-executable#
Community Moderator
June 13, 2024
Hello @EB_10109450,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
