Editable Combo box in Thingworx 8.5.3
I am looking for the Combobox where I can select the value and add new value as well.
Do we have any widgets in Thingworx available so that I can use the same?
Thank you in advance.
anarwalAnswer
you can select easily to add new values you have to change the service output based on some condition which you have binded to combo
Hello @ravik_344332 ,
I am not sure if I understood correctly your use case but do you want to enable multi-select on combobox widget (List Widget) because you can do that by enable MultiSelect option.  Do you want to assign the values to a service ?
One article is https://www.ptc.com/en/support/article/CS303137
Hope it helps,
anarwal5-Regular MemberAnswer
Support
Hi @ravik_344332.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others in the community.
--Sharon
