Edited Table does not work if Grid is placed in a layout control.
I have a grid widget placed in the layout control and have two columns select(with check box) and property(string)
and made iseditable to true and multiselect to true of the grid properties. Also i have made the editable to true of the column select. (made by default top 5 rows selected)
On a event i am passing editabletable property of the grid as parameter, irrespective of selecting any no. of rows the editabletable property of the grid is always same.
But when i move the grid from layout to panel, i see the editabletable property working.
Is this the intended behavior or there is an issue with the grid.?
I think there no issue with the grid. Once try in modifying the values in Column Renderer & StateFormatting Tab in Configure grid columns
sbt15-MoonstoneAuthor
Hello @SaiSameera,
Renderer is boolean and Format is Checkbox.
But do you want me to change that..?
No need to change the value. Is the values of check box for default selected rows is true.
