Empty grid tooltip
I was wondering if perhaps someone on here knew why my overflow tooltips do not work:
I can't seem to find any settings for it other than these:
So if anyone could point me in the right direction, that'd be highly appreciated!
Jens
DanZAnswer
I'm also just realizing that inspection with dev tools is easier said than done. I just saw that you can at least find the tooltip text under "aria-label" on the element.
In example for a button with a tooltip "Search entities":
<ptcs-button class="ptcs-wrapper widget-content widget-ptcsbutton" tabindex="0" id="root_pagemashupcontainer-5_ptcsbutton-280" variant="primary" icon-placement="left" content-align="center" role="button" mode="icon" aria-disabled="false" aria-label="Search entities"></ptcs-button>
To style the tooltips you have a small section in the StyleTheme for it: Elements -> Information -> Tooltips.
Just to be sure: Have you checked the tooltip with the Dev-Browsertool? Is the contained text missing or does it simply have the same color as the background?
jensc17-PeridotAuthor
Hello @DanZ ,
I've tried to figure out how to check this in the dev tools, but have not been able to even using the "force state:hover".
Could you perhaps point me in the right direction?
I also do not believe there is any OOTB style property to change the tooltip text color...
Jens
DanZ15-MoonstoneAnswer
