EMS on Raspberry Pi, error connecting
While trying to connect my Raspberry 3 B+ to Platform, i get this error when doing : sudo ./luaScriptResource  :
[FORCE] 2020-09-26 14:10:45,205 ./luaScriptResource: Starting up ....
[INFO ] 2020-09-26 14:10:45,208 luaScriptResource:main: Encryption is disabled on the RAP connection.
[INFO ] 2020-09-26 14:10:45,208 luaScriptResource:main: FIPS is disabled.
[INFO ] 2020-09-26 14:10:45,209 ./luaScriptResource: New path is /home/pi/Desktop/microserver/etc/thingworx/clibs:/home/pi/Desktop/microserver/etc/custom/clibs:/home/pi/Desktop/microserver/etc/community/clibs:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
[WARN ] 2020-09-26 14:10:45,210 ScriptResource::initialize: Encryption is disabled on HTTP Server.
[ERROR] 2020-09-26 14:10:45,210 ScriptResource::initialize: Failed to get HTTP Server authenticate configuration.
[ERROR] 2020-09-26 14:10:45,210 ./luaScriptResource: Error initiatizing script resource
[ERROR] 2020-09-26 14:10:45,210 luaScriptResource:main: Insecure configuration. Shutting down LSR.
[WARN ] 2020-09-26 14:10:46,211 luaConfigurator::~luaConfigurator: Closing Lua state
Myabe something wrong in my config ?
config.lua
scripts.log_level = "INFO"
scripts.script_resource_ssl = false
scripts.script_resources_authenticate = false
scripts.PiThing = {
 file = "thing.lua",
 template = "PiTemplate",
 scanRate = 1000,
 taskRate = 30000
scripts.rap_host = "127.0.0.1"
scripts.rap_port = 8080
scripts.data_security_key_hash="4vt6VnYj+93wOHypT0jFoIwvk93bsM3UA7n1WAS7FqQ"
config.json
 "ws_servers": [{
 "host": "pp-2009221255A9.devportal.ptc.io",
 "port": 443
 "appkey": "a814e827-9f06-41a3-bbeb-7b615abbe3df",
 "http_server": {
 "host": "127.0.0.1",
 "port": 8080,
 "use_default_certificate": true,
 "ssl": false,
 "authenticate": false
 "logger": {
 "level": "INFO"
 "certificates": {
 "validate": false,
 "disable_hostname_validation": true
I'm using Thingworx platform 9.0 Trial
What version of EMS are you using?
The latest version of EMS has changed to disallow default insecure behavior.
Try this config file that explicitly turns off security features:
scripts.script_resource_authenticate = false
scripts.script_resource_host = "127.0.0.1"
scripts.script_resource_port = 8001
scripts.PiThing = {
file = "thing.lua",
scanRate = 1000,
taskRate = 30000
scripts.rap_ssl = false
scripts.rap_server_authenticate = false
Does anyone have an idea ?
Thank you
scripts.PiThing = {
file = "thing.lua",
scanRate = 1000,
taskRate = 30000
Thank you for your answer.
I used your file, i had this error :
[ERROR] 2020-10-01 12:33:38,698 luaConfigurator::initialize: Error while loading file /home/pi/Desktop/microserver/etc/config.lua. msg: /home/pi/Desktop/microse rver/etc/config.lua:5: malformed number near '127.0.0.1'
So i added some " ", it's going better and now i have this one :
pi@raspberrypi:~/Desktop/microserver $ sudo ./luaScriptResource
[FORCE] 2020-10-01 12:40:28,988 ./luaScriptResource: Starting up ....
[INFO ] 2020-10-01 12:40:28,992 luaScriptResource:main: Encryption is disabled on the RAP connection.
[INFO ] 2020-10-01 12:40:28,992 luaScriptResource:main: FIPS is disabled.
[INFO ] 2020-10-01 12:40:28,995 ./luaScriptResource: New path is /home/pi/Desktop/microserver/etc/thingworx/clibs:/home/pi/Desktop/microserver/etc/custom/clibs:/home/pi/Desktop/microserver/etc/community/clibs:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
[WARN ] 2020-10-01 12:40:28,996 ScriptResource::initialize: Encryption is disabled on HTTP Server.
[WARN ] 2020-10-01 12:40:28,997 ScriptResource::initialize: Authentication is disabled on the HTTP Server.
[FORCE] 2020-10-01 12:40:29,25 httpServer: starting http server port=8001
[INFO ] 2020-10-01 12:40:29,41 thingworx.shape: Creating a new shape.
[INFO ] 2020-10-01 12:40:29,42 PiThing: -- Configuration -------------------------------
[INFO ] 2020-10-01 12:40:29,42 PiThing: scanRate: 1000
[INFO ] 2020-10-01 12:40:29,42 PiThing: scanRateResolution: 500
[INFO ] 2020-10-01 12:40:29,42 PiThing: taskRate: 30000
[INFO ] 2020-10-01 12:40:29,42 PiThing: keepAliveRate: 60000
[INFO ] 2020-10-01 12:40:29,42 PiThing: requestTimeout: 15000
[INFO ] 2020-10-01 12:40:29,42 PiThing: registerRate: 43200000
[INFO ] 2020-10-01 12:40:29,43 PiThing: register: true
[INFO ] 2020-10-01 12:40:29,43 PiThing: getPropertySubscriptionOnReconnect: false
[INFO ] 2020-10-01 12:40:29,43 PiThing: maxConcurrentPropertyUpdates: 100
[INFO ] 2020-10-01 12:40:29,43 PiThing: defaultPushType: VALUE
[INFO ] 2020-10-01 12:40:29,43 PiThing: useShapes: true
[INFO ] 2020-10-01 12:40:29,43 PiThing: identifier: Not Specififed
[INFO ] 2020-10-01 12:40:29,43 PiThing: ------------------------------------------------
[INFO ] 2020-10-01 12:40:29,44 thingworx.template: Adding shape 'shapes.metadata' to template 'thingworx.template'
[INFO ] 2020-10-01 12:40:29,45 thingworx.template: Adding shape 'shapes.propsubscribe' to template 'thingworx.template'
[INFO ] 2020-10-01 12:40:29,45 thingworx.template: Creating new templates.PiTemplate named 'PiThing'
[INFO ] 2020-10-01 12:40:29,45 PiThing: -- Initializing properties ---------------------
[INFO ] 2020-10-01 12:40:29,45 PiThing: Initialized property upToDate [baseType: BOOLEAN, pushType: NEVER, handler: nil, value: true]
[INFO ] 2020-10-01 12:40:29,46 PiThing: Initialized property cpu_volt [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0]
[INFO ] 2020-10-01 12:40:29,46 PiThing: Initialized property cpu_temperature [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0]
[INFO ] 2020-10-01 12:40:29,46 PiThing: Initialized property cpu_freq [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0]
[INFO ] 2020-10-01 12:40:29,46 PiThing: ------------------------------------------------
[INFO ] 2020-10-01 12:40:31,15 PiThing: -- Starting script --------------------------
[INFO ] 2020-10-01 12:40:31,15 PiThing: Registering core callback handler
[INFO ] 2020-10-01 12:40:31,16 PiThing: Starting main loop
[INFO ] 2020-10-01 12:40:31,16 PiThing: Calling lifecycle start listeners.
[INFO ] 2020-10-01 12:40:31,16 shapes.propsubscribe: Initialized
[INFO ] 2020-10-01 12:40:31,17 thingworx.handler: Creating a new handler.
[INFO ] 2020-10-01 12:40:31,36 PiThing: MicroServer is now available.
[INFO ] 2020-10-01 12:40:31,36 PiThing: MicroServer is online.
[INFO ] 2020-10-01 12:40:31,36 PiThing: Successfully registered PiThing with MicroServer.
[INFO ] 2020-10-01 12:40:31,671 PiThing: Error occured while accessing EMS. Checking isConnected.
[INFO ] 2020-10-01 12:40:31,678 PiThing: EMS is available: true, online: true
[INFO ] 2020-10-01 12:40:31,678 PiThing: Attempting to GetPropertySubscriptions from server failed. code: 202, result:
[ERROR] 2020-10-01 12:40:31,695 luaScriptProxy::execute: [1979708496] Error executing script PiThing, Error = Error: ...ktop/microserver/etc/custom/templates/PiTemplate.lua:32: attempt to perform arithmetic on local 's' (a nil value)
[ERROR] 2020-10-01 12:40:31,695 luaScriptProxy::app_unlock: [1979708496] Attempt to unlock app_mutex while not holding it.L= 0x1bd6420
Looks like there is still 2 errors, one in PiTemplate and the other one... i have no clue.
I don't know which version of EMS i'm using, and don't know where to find this info (i did search)
