Dec 13, 2019 1:48 PM UTC
EMS: Which protocols can be tunneled?
I establish a ssh connection without problems. RDP works sometime but not on my PC. Thrid I need to tunnel an webserver (port 80 or in special case 4444).
which protocols can be tunneled via EMS with Thingworx Remote Access Client?
22-Sapphire I
Dec 13, 2019 4:52 PM UTC
First of all my knowledge on this is probably 2-3 years old but originally, the EMS tunnel capability provides a single TCP/IP end point.
What have I seen working with that is ssh and RDP as well as some connections where you can point a Client to a Server like RS Linx to an RS PLC or Siemens Simatic Step 7 client connection to Siemens PLC
I've heard of use cases where somehow even connections were possible where two end points were needed, not sure though where to find that info.
