Entities importing Error: error, Invalid byte 1 of 1-byte UTF-8 sequence (Windows Machines)
I'm trying to import Project tagged Entities(i.e. entities.xml) from one machine i.e. Dev to another Test machine but getting below error:-
Error importing: error, Not Acceptable
"Internal error: com.sun.org.apache.xerces.internal.impl.io.MalformedByteSequenceException: Invalid byte 1 of 1-byte UTF-8 sequence"
1st machine(from which export has been taken) is having ThingWorx v8.3 and Manufacturing Apps v8.3.2
2nd machine(Entities to which import required) is having ThingWorx v8.4.4 and Manufacturing Apps v8.3.2
I already added Java Options in tomcat as mentioned when I installed tomcat :-
-Dserver -Dd64
-XX:+UseG1GC
-Dfile.encoding=UTF-8
-Djava.library.path=C:\Program Files\Apache Software Foundation\Tomcat 8.5\webapps\Thingworx\WEB-INF\extensions
Still I am getting the error when trying to import the entites.xml file.
Please help on this issue.
Thanks in advance.
  Are both servers set to use UTF-8?
-Chris Kaminski
ranjank1-VisitorAuthor
Yes.
Also in both servers Java Options are set i.e. -Dfile.encoding=UTF-8.
Is it possible for you to test the source file:
  https://stackoverflow.com/questions/115210/how-to-check-whether-a-file-is-valid-utf-8
-Chris
Have you already set extension import enabled (allowEntities) in platform-settings.json per article CS300115?
Yes, it is already set as mentioned:-
"ExtensionPackageImportPolicy": {
        "importEnabled": true,
      "allowJarResources": true,
      "allowJavascriptResources": true,
      "allowCSSResources": true,
      "allowJSONResources": true,
      "allowWebAppResources": true,
      "allowEntities": true,
      "allowExtensibleEntities": true
We normally only set -Dfile.encoding=UTF-8 property to JAVA_OPTS Java options for tomcat. If it doesn't work, please use below workaround for a try:
  1. Open the XML in notepad
  2. No extra space should be there at the beginning and end of the document
  3. Select File -> Save As
  4. Select save as type -> All files
  5. Enter file name as abcd.xml
  6. Select Encoding as UTF-8 -> Click Save
