EntityServices CreateThing Service does not apply Default Values
Hello everyone,
I've been trying to create 'Thing' in a batch mode, and I've decided to use the Resources["EntityServices"] CreateThing().
The service seems to work as intended. However, I can verify that the 'Thing' properties of my newly created Thing do not have the 'Default Values' I have configured. Has anyone had an issue with this in the past?
Note: I'm using v8.4.1
vinakumarAnswer
For your reference , this is the service code I am using
   var text    = '';
   var characters       = 'ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789';
    for ( var i = 0; i < 6; i++ ) {
      text += characters.charAt(Math.floor(Math.random() * i));
try {
var params = {
 name: text /* STRING */,
 description: undefined /* STRING */,
 thingTemplateName: 'MyThingTemplate' /* THINGTEMPLATENAME */,
 tags: undefined /* TAGS */
// no return
Resources["EntityServices"].CreateThing(params);
catch (err)
    logger.warn (err.message);
try {
     Things[text].EnableThing();
     Things[text].RestartThing();
catch (err)
Please define ThingTemplate with name "MyThingTemplate" with default property values before using above service code.
Are you creating Thing  from specific ThingTemplate which have some properties with default values ? If you are creating thing from Generic Thing template, then how you are setting default property values on thing . Please share that code.
rnfonseca1-VisitorAuthor
Hello @vinakumar ,
I'm creating a thing from a specific ThingTemplate which has some properties with default values.
I am not seeing any issue at my end in seeing the default property values for Things created dynamically.
