Error connecting Raspberry EMS to Thingworx Composer
Hi Allen,
In the explanation you've linked to "Using the Edge MicroServer and LSR in a Gateway Scenario" it says:
  1. Make sure the ThingWorx platform is running
  2. Create a RemoteThing with the name given in the auto_bind section for the LSR we are connecting
  3. Create an EMSGateway with the name given in the auto_bind section for the EMS as a Gateway to bind to
I've been following the Developer Portal Guide "Connect a Raspberry Pi to ThingWorx using the Edge Micro Server (EMS)." Using that it has set the name in the auto_bind section for EMS to "PiThing" and the auto_bind name section for the LSR is also "PiThing". This therefore implies that the name in both those auto_bind name sections should be the same. However, I cannot create a RemoteThing and an EMSGateway thing both with the same name.
Can you please advise me on what I should be doing in this situation?
Thanks in advance!
Charlotte
