Error - Error executing batch
Hi All,
I am using Thingworx 7.3. It throwing error ("Error executing batch") continuously on Application Log. I don't have any idea about this.
What is this error?
I have recently imported Relational Databases Connectors extension from Thingworx market place. Is there any idea about this?
Thanks & Regards,
Sathishkumar C.
Hi Sathishkumar, have you checked if there is any scheduler or timer executing in the background? May be one you created or it simply got created when you imported some extension?
Could you add the application log here so we could review it?
This message was migrated to our current platform in March 2026. This platform cannot support a post with more than 100k characters. As a result, the message has been truncated. We saved the full length original post as a txt file, attached below. Thanks for your understanding.
The Community team.
April 2026
Thank you for your response.
Here the logs,
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] FileTransfer Subsystem Settings
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ----------------------------------------
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Thread Pool Minimum Size = 10
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Thread Pool Maximum Size = 10
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Queue Size = 100
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Thread Life = 600000
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] File Transfer Idle Timeout = 30000
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max File Transfer Size = 100000000
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max File Transfers Allowed in Offline Queue = 50000
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max File Transfers Allowed Per Thing in Offline Queue = 10
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Time To Live (sec) of File Transfer in Offline Queue = 86400
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] FileTransfer Idle Timeout for Edge Controlled Transfers = 600000
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Concurrent Edge Controlled File Transfers Allowed = 500
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.s.f.FileTransferSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Max Concurrent Edge Controlled File Transfers Allowed Per Thing = 2
2017-12-15 09:15:02.404+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Starting All Things...
2017-12-15 09:15:02.404+0530 [L: WARN] [O: c.t.t.Thing] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-1-worker-2] Thing [SubStation01] has logged properties but does not have a valid value stream assigned
2017-12-15 09:15:02.404+0530 [L: WARN] [O: c.t.t.Thing] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-1-worker-2] Thing [En.Navigation03] has logged properties but does not have a valid value stream assigned
2017-12-15 09:15:02.404+0530 [L: WARN] [O: c.t.t.Thing] [I: ] [U: SuperUser] [S: ] [T: ForkJoinPool-1-worker-2] Thing [demothing] has logged properties but does not have a valid value stream assigned
2017-12-15 09:15:03.091+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Activating Subscriptions...
2017-12-15 09:15:03.091+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Activating Property Bindings...
2017-12-15 09:15:03.091+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Initializing Subscriptions relationships...
2017-12-15 09:15:03.106+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Initializing Property Binding relationships...
2017-12-15 09:15:03.106+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Sending Post Start Notifications...
2017-12-15 09:15:03.153+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Thingworx Server Application...ON
2017-12-15 09:15:03.481+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Datastore database...INITIALIZED
2017-12-15 09:15:10.501+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:16:02.408+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-16-thread-1]  Thingworx System Metrics
AlertProcessingSubsystem#,         maximumQueueSize= 50000.0, queueSize= 4.0, totalAlertsQueued= 4.0,
AlwaysOnSubsystem#,                messageQueueSize= 0.0, messageThreadPoolSize= 0.0, messageActiveThreadCount= 0.0, messageLargestPoolSize= 0.0, messageCompletedTaskCount= 0.0, minaThreadPoolSize= 0.0, minaActiveThreadCount= 0.0, minaLargestPoolSize= 0.0, minaCompletedTaskCount= 0.0,
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 5.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 5.0, submitedTaskCount= 5.0, completedTaskCount= 5.0,
FederationSubsystem#,              clientCount= 0.0, publishedCount= 0.0, updateInterval= 100.0,
FileTransferSubsystem#,            corePoolSize= 10.0, maxPoolSize= 10.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
MessageStoreSubsystem#,            corePoolSize= 10.0, maxPoolSize= 100.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.35846784E8, totalMemoryAllocated= 6.0817408E8, thingCount= 42.0,
StreamProcessingSubsystem#,        maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 250000.0, queueSize= 0.0, totalWritesQueued= 0.0, totalWritesPerformed= 0.0, numberOfProcessingThreads= 5.0,
TunnelSubsystem#,                  activeTunnelCount= 0.0, totalTunnelCount= 0.0,
UserManagementSubsystem#,          userCount= 2.0,
ValueStreamProcessingSubsystem#,   maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 500000.0, queueSize= 0.0, totalWritesQueued= 251.0, totalWritesPerformed= 251.0, numberOfProcessingThreads= 5.0,
WSCommunicationsSubsystem#,        activeWebsockets= 0.0,
WSExecutionProcessingSubsystem#,   corePoolSize= 1000.0, maxPoolSize= 10000.0, curentPoolSize= 0.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 0.0, submitedTaskCount= 0.0, completedTaskCount= 0.0,
ThingworxServer#,                  systemRuntime= 0 hours,  memoryInUse = 0.236 GB,  totalMemoryAllocated= 0.608 GB,  activeUsers= 0, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2017-12-15 09:16:03.354+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:16:13.224+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:16:58.549+0530 [L: ERROR] [O: c.t.p.p.PostgresDataExceptionTranslator] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [message: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]]
2017-12-15 09:16:58.616+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@140e0d66][message: Execution error in service script [En.DataAccess Last30DaysPeakLoad] : Wrapped java.lang.RuntimeException: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.] Cause: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]]
2017-12-15 09:17:03.127+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:17:13.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:18:03.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:18:13.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:19:03.238+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:19:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:20:03.127+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:20:13.123+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:21:03.240+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:21:13.148+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:22:03.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:22:13.123+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:23:03.193+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:23:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:24:03.143+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:24:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:25:03.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:25:13.248+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:26:03.198+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:26:13.136+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:27:03.147+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:27:13.140+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:28:03.175+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:28:13.153+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:29:03.162+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:29:13.144+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:30:03.138+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:30:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:31:03.187+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:31:13.175+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:32:03.200+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:32:13.148+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:33:03.138+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:33:13.145+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:34:03.200+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:34:13.165+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:35:03.168+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:35:13.147+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:36:03.174+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:36:13.143+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:37:03.158+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:37:13.136+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:38:03.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:38:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:39:03.143+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:39:13.150+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:40:03.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:40:13.142+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:41:03.161+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:41:13.156+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:42:03.161+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:42:13.140+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:43:03.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:43:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:44:03.165+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:44:13.146+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:45:03.212+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:45:13.139+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:46:02.490+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-16-thread-1]  Thingworx System Metrics
AlertProcessingSubsystem#,         maximumQueueSize= 50000.0, queueSize= 5.0, totalAlertsQueued= 5.0,
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 155.0, completedTaskCount= 155.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 2.98451328E8, totalMemoryAllocated= 9.1226112E8, thingCount= 42.0,
ValueStreamProcessingSubsystem#,   maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 500000.0, queueSize= 0.0, totalWritesQueued= 6543.0, totalWritesPerformed= 6543.0, numberOfProcessingThreads= 5.0,
ThingworxServer#,                  systemRuntime= 0 hours,  memoryInUse = 0.298 GB,  totalMemoryAllocated= 0.912 GB,  activeUsers= 1, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2017-12-15 09:46:03.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:46:08.292+0530 [L: ERROR] [O: c.t.p.p.PostgresDataExceptionTranslator] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [message: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]]
2017-12-15 09:46:08.298+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@29676d2a][message: Execution error in service script [En.DataAccess Last30DaysPeakLoad] : Wrapped java.lang.RuntimeException: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.] Cause: com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]]
2017-12-15 09:46:13.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:46:40.059+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@499608bb][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:47:03.153+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:47:10.031+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@62c03879][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:47:13.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:47:40.020+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@1c8f5631][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:48:03.163+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:48:10.037+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@23b760b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:48:13.149+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:48:40.006+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@23c3b00b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:49:03.151+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:49:10.044+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@58c831a9][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:49:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:49:40.020+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@4dc7457b][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:50:03.224+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:50:10.032+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@60177cfb][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:50:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:50:40.007+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@1bdae1c0][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:51:03.152+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:51:09.987+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@649f00c4][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:51:13.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:51:40.009+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@477cc814][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:52:03.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:52:10.017+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@36748326][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:52:13.140+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:52:40.010+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@57f57ee8][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:53:03.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:53:10.038+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@1f886234][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:53:13.129+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:53:40.043+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@5118e3fd][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:54:03.182+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:54:10.029+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@3a32b5c8][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:54:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:54:40.024+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@79ff64bd][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:55:03.149+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:55:10.031+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@7db7c929][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:55:13.136+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:55:40.030+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@30e6c158][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:56:03.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:56:10.033+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@3df5f48c][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:56:13.128+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 09:56:40.043+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@49628c9a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:57:03.136+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 09:57:10.054+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@27c405e7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:57:13.141+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:57:40.043+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@57d39fdf][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:58:03.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 09:58:10.055+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@16b8604e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:58:13.136+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:58:40.066+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@5b537bad][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:59:03.163+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 09:59:10.021+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@2ef3f85d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 09:59:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 09:59:40.045+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@601db0e7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:00:03.149+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:00:10.096+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@7fbb51e9][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:00:13.145+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:00:40.044+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@24da35e0][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:01:03.171+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:01:10.044+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@6b7973b1][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:01:13.135+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:01:40.033+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@5e2f51d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:02:03.151+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:02:10.047+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@61d59d11][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:02:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:02:40.043+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@6033eaf8][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:03:03.164+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:03:10.083+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@3ef5dd21][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:03:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:03:40.054+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@5573ee5a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:04:03.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:04:10.061+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@112b2399][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:04:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:04:40.091+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@d5596ca][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:05:03.145+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:05:10.173+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@177a807c][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:05:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:05:40.101+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@5747131c][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:06:03.167+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:06:10.068+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@16e81113][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:06:13.151+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:06:40.061+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@96972c9][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:07:03.153+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:07:10.089+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@5bb268d4][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:07:13.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:07:40.057+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@1d2671d4][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:08:03.178+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:08:10.085+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@3e6689d0][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:08:40.078+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@45e913c1][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:09:03.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:09:10.075+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@78cc82a7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:09:13.139+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:09:40.052+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@3be2fd41][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:10:03.167+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:10:10.085+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@2b441e7f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:10:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:10:40.078+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@3a5feb84][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:11:03.127+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:11:10.210+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@6aa8cc94][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:11:13.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:11:40.085+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@1241b4cf][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:12:03.174+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:12:10.083+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@5f6cb610][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:12:13.150+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:12:40.111+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@4729c216][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:13:03.126+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:13:10.133+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@28cf62b7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:13:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:13:38.692+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@2828ab0f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:14:03.121+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:14:10.187+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@3426627c][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:14:13.122+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:14:40.110+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@f9aebae][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:15:03.146+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:15:10.114+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@4035c3f6][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:15:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:15:40.103+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@56ea0465][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:16:02.597+0530 [L: WARN] [O: c.t.s.s.p.PlatformSubsystem] [I: ] [U: SuperUser] [S: ] [T: pool-16-thread-1]  Thingworx System Metrics
AlertProcessingSubsystem#,         maximumQueueSize= 50000.0, queueSize= 13.0, totalAlertsQueued= 13.0,
EventProcessingSubsystem#,         corePoolSize= 16.0, maxPoolSize= 500.0, curentPoolSize= 16.0, activeThreads= 0.0, queueSize= 0.0, largestPoolSize= 16.0, submitedTaskCount= 305.0, completedTaskCount= 305.0,
PlatformSubsystem#,                eventQueueSize= 0.0, streamQueueSize-ThingworxPersistenceProvider= 0.0, valueStreamQueueSize-ThingworxPersistenceProvider= 0.0, memoryInUse= 5.92518328E8, totalMemoryAllocated= 9.1226112E8, thingCount= 42.0,
ValueStreamProcessingSubsystem#,   maximumWaitTime= 10000.0, sizeThreshold= 1000.0, maximumBlockSize= 2500.0, scanRate= 5.0, maximumQueueSize= 500000.0, queueSize= 0.0, totalWritesQueued= 12883.0, totalWritesPerformed= 12883.0, numberOfProcessingThreads= 5.0,
ThingworxServer#,                  systemRuntime= 1 hours,  memoryInUse = 0.593 GB,  totalMemoryAllocated= 0.912 GB,  activeUsers= 1, BoundConnectedThings= 0, UnBoundConnectedThings= 0
2017-12-15 10:16:03.124+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:16:10.190+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@67acb34f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:16:13.122+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:16:40.130+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@23bb38d3][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:17:03.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:17:10.118+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@70d1308][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:17:13.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:17:40.107+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@5b3c431f][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:18:03.142+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:18:10.143+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@1edd543d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:18:13.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:18:40.105+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@1e0e50c7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:19:03.124+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:19:10.119+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@1868f95d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:19:13.122+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:19:40.103+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@5b6ab50][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:20:03.126+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:20:10.144+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@63df1de2][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:20:13.123+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:20:40.249+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@239cd5af][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:21:03.118+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:21:10.114+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@4a2ab8c1][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:21:13.120+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:21:40.104+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@1ff2f14d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:22:03.122+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:22:10.149+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@2610828d][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:22:11.122+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@702839f3][message: Execution error in service script [En.AlertsAndEvents NumberOfUnackAlerts] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Execution error in service script [En.AlertsAndEvents AllUnackAlerts] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Execution error in service script [En.AlertsAndEvents AllAlerts] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Thing [EnSystem05] is not running Cause: Thing [EnSystem05] is not running Cause: Execution error in service script [En.AlertsAndEvents AllAlerts] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Thing [EnSystem05] is not running Cause: Thing [EnSystem05] is not running Cause: Execution error in service script [En.AlertsAndEvents AllUnackAlerts] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Execution error in service script [En.AlertsAndEvents AllAlerts] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Thing [EnSystem05] is not running Cause: Thing [EnSystem05] is not running Cause: Execution error in service script [En.AlertsAndEvents AllAlerts] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Thing [EnSystem05] is not running Cause: Thing [EnSystem05] is not running]
2017-12-15 10:22:13.118+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:22:38.162+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:22:40.111+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@6207f4df][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:23:03.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:23:10.136+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@5593c067][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:23:13.137+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:23:40.112+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@3b3d7244][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:24:03.141+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:24:10.144+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@6082c6da][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:24:13.128+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:24:40.125+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@5e583833][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:25:03.138+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:25:10.107+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@7a8473be][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:25:13.128+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:25:40.135+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@1120cfe5][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:26:03.120+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:26:10.132+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@777af16e][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:26:13.122+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:26:40.152+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@84d4fec][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:27:03.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:27:10.163+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@4c33d101][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:27:13.122+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:27:40.122+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-1] [context: com.thingworx.webservices.context.HttpExecutionContext@37d397e7][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:28:03.164+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:28:10.142+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@1619a80][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:28:13.138+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:28:40.155+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@2df9a520][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:29:03.144+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:29:10.153+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@602bd058][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:29:13.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:29:40.133+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@31addcd4][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:30:03.125+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:30:10.151+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@a939ab1][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:30:13.122+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:30:40.164+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@21d13877][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:31:03.170+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:31:10.170+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@1a727f66][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:31:13.132+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:31:40.154+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-9] [context: com.thingworx.webservices.context.HttpExecutionContext@2206abd3][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:32:03.133+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:32:10.150+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@64a013a0][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:32:13.127+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-2] Error executing batch
2017-12-15 10:32:40.165+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@4e6ef20a][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:33:03.130+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:33:10.163+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@70819dfc][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:33:13.128+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:33:40.163+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-2] [context: com.thingworx.webservices.context.HttpExecutionContext@46ffd352][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:34:03.167+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:34:10.152+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-7] [context: com.thingworx.webservices.context.HttpExecutionContext@2590424][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:34:13.139+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:34:40.173+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@33590497][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:35:03.166+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:35:10.168+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-6] [context: com.thingworx.webservices.context.HttpExecutionContext@1f8693c2][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:35:13.152+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:35:40.151+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@3b125194][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:36:03.134+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-4] Error executing batch
2017-12-15 10:36:10.179+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-8] [context: com.thingworx.webservices.context.HttpExecutionContext@17be6ceb][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:36:13.131+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-3] Error executing batch
2017-12-15 10:36:40.175+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@126a1f37][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:37:03.175+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:37:10.187+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-4] [context: com.thingworx.webservices.context.HttpExecutionContext@1f14117][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:37:13.147+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-1] Error executing batch
2017-12-15 10:37:40.179+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-5] [context: com.thingworx.webservices.context.HttpExecutionContext@1a5763fc][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:38:03.180+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U: SuperUser] [S: ] [T: pool-2-thread-5] Error executing batch
2017-12-15 10:38:10.210+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Administrator] [S: ] [T: http-nio-8080-exec-10] [context: com.thingworx.webservices.context.HttpExecutionContext@2b334c6][message: Execution error in service script [EnSystem05 TodayEnergyDelivered] : Wrapped java.lang.IndexOutOfBoundsException: Index: 0, Size: 0 Cause: Index: 0, Size: 0]
2017-12-15 10:38:13.147+0530 [L: ERROR] [O: c.t.p.p.BatchStreamEntryProcessor] [I: ] [U:
See the attachment for the full content of the post
The Community team
April 2026
Thank you for sharing, its generated by the BatchStreamEntryProcessor, looks like some issue with the processing of stream entries, I also notice that you have DataStore unknown error for PostgreSQL. Are you using PostgreSQL as your persistence provider? If yes could you confirm that there are no connectivity issues.
How often are you writing to the Stream? Does the issue persist despite server restart?
Anyone..
This problem ("Error executing batch'") still persists. Anyone having idea regarding this.
It will be very helpful, if any solution available for this issue...
I can't able to access history of logged property.
Thanks & Regards,
Sathishkumar C
Hi Sathishkumar C​ if you have access to the PTC Support, could you please open a support case for this. I think it needs to be reviewed live may be with a Webex session.
OK .
Thank you.
