Feb 27, 2017 9:09 AM UTC
Error executing service
Unable to Invoke Service SendMessage on Mail_Test : 250-I3LCAS6.ITCINFOTECH.com Hello [-------] 250-SIZE 15728640 250-PIPELINING 250-DSN 250-ENHANCEDSTATUSCODES 250-STARTTLS 250-X-ANONYMOUSTLS 250-AUTH GSSAPI NTLM 250-X-EXPS GSSAPI NTLM 250-8BITMIME 250-BINARYMIME 250-CHUNKING 250 XRDST
Feb 27, 2017 9:13 AM UTC
Balkrishna, are you setting your mail extension for the first time use, or was it working before? Which service exactly are you using, i mean is it a simple send or is it send email with attachment / image? Could you also state which ThingWorx version are you on? Are you configuring your organization's email server?
bjadhav1-VisitorAuthor
Feb 27, 2017 9:26 AM UTC
I am using mail extension first time. using simple send message service.I am using organization's email server.
Feb 27, 2017 9:35 AM UTC
How exactly are you getting that error, is it while using that service within a mashup or are you simply trying to Test the service? Are you able to successfully test the Read and Send email services directly from the Services section?
