Jun 21, 2017 7:04 PM UTC
Error importing: error, Not Acceptable
Was able to import files and extensions without a problem earlier this week and not I just receive this message.
20-Turquoise
Jun 21, 2017 7:36 PM UTC
What is your Thingworx platform version and what is the extension you are trying to install? What is the extension version? Was it downloaded from the marketplace or is it custom developed?
rmasoud11-VisitorAuthor
Jun 21, 2017 8:12 PM UTC
ThimgWorx 8.0.0 and I am completing some courses and need to import a few files from the lab and demo files.
20-Turquoise
Jun 21, 2017 8:15 PM UTC
make sure you are importing .twx and .xml files as entities, and json as data; .zip as extension (and ensure to unarchive those extensions that are double zipped)
20-Turquoise
Jun 21, 2017 8:49 PM UTC
I am able to import it with no problem. What version of thingworx are you on?
Jun 22, 2017 2:11 PM UTC
I am using 8.0.0. Looking at the log I keep getting this error.
Unable to process import: ERROR adding User with name = [ThingWorxStudent]: [1,018] Data store unknown error: [Error occurred while accessing the model provider.]
20-Turquoise
Jun 22, 2017 2:19 PM UTC
Where did you download the demo file from? It might not be compatible with 8.0
Sep 12, 2017 2:11 PM UTC
I am having the same error trying to import a file from an trial server to another trial server.
I tried it with .xml and .twx, both giving me the same error,
I have installed the same extensions on both platforms.
Is the source of this error known?
Thank you in advance.
Marcel
Sep 12, 2017 3:03 PM UTC
Are you transferring from the same database or different.
Sep 12, 2017 4:41 PM UTC
I am not sure, are you refering to the thingworx Storage option?
I am acessing the platforms in the same computer, exporting the entities as files from one and trying to import to another.
As far as I know they are in the same server, and they have the same thingworx version.
