Jun 30, 2014 12:29 PM UTC
Error in Custom Object logs
Hi
In my Custom Object logs I found some errors that I can't make sense of (see below). I also don't know which Custom Object is generating this error. Can someone tell me what could result in such an error? This could help me find the Custom Object and hopefully also what in that CO is causing this.
ERROR 2014-06-30 11:08:59,055 [ExpressionErrorLog,triggerableEventJmsListenerTemplate-72] Error while evaluating JEP Expression: Asset is not belongs to Action associated Model.: com.singularsys.jep.EvaluationException: Asset is not belongs to Action associated Model.
  at com.axeda.drm.rules.functions.ExecuteAction.checkCanExecuteAction(ExecuteAction.java:298)
  at com.axeda.drm.rules.functions.ExecuteAction.eval(ExecuteAction.java:158)
  at com.singularsys.jep.standard.FastEvaluator.visitFun(Unknown Source)
  at com.singularsys.jep.standard.FastEvaluator.nodeAccept(Unknown Source)
  at com.singularsys.jep.standard.FastEvaluator.evaluate(Unknown Source)
  at com.singularsys.jep.Jep.evaluate(Unknown Source)
  at com.axeda.drm.rules.engine.JepExpressionParser.evaluate(JepExpressionParser.java:321)
  at com.axeda.drm.rules.engine.ExpressionRule.evaluate(ExpressionRule.java:168)
  at com.axeda.drm.rules.ExpressionEngineImpl.evaluateExpressionRule(ExpressionEngineImpl.java:400)
  at com.axeda.drm.rules.ExpressionEngineImpl.evaluate(ExpressionEngineImpl.java:356)
  at com.axeda.drm.rules.ExpressionEngineImpl.evaluate(ExpressionEngineImpl.java:89)
  at com.axeda.drm.rules.RulesManagerImpl.evaluate(RulesManagerImpl.java:797)
  at com.axeda.drm.rules.RulesExecutorImpl.run(RulesExecutorImpl.java:63)
  at com.axeda.drm.rules.ThreadWatcher.runWithDeadline(ThreadWatcher.java:156)
  at com.axeda.drm.rules.ThreadWatcher.runRuleWithDeadline(ThreadWatcher.java:168)
  at com.axeda.drm.rules.RulesExecutorMonitor.run(RulesExecutorMonitor.java:60)
  at com.axeda.drm.eda.handler.TriggerableItemEventProcessor.processEvent(TriggerableItemEventProcessor.java:109)
  at com.axeda.common.eda.jms.DefaultJMSEventConsumer.onMessage(DefaultJMSEventConsumer.java:233)
  at org.springframework.jms.listener.AbstractMessageListenerContainer.doInvokeListener(AbstractMessageListenerContainer.java:535)
  at org.springframework.jms.listener.AbstractMessageListenerContainer.invokeListener(AbstractMessageListenerContainer.java:495)
  at org.springframework.jms.listener.AbstractMessageListenerContainer.doExecuteListener(AbstractMessageListenerContainer.java:467)
  at org.springframework.jms.listener.AbstractPollingMessageListenerContainer.doReceiveAndExecute(AbstractPollingMessageListenerContainer.java:325)
  at org.springframework.jms.listener.AbstractPollingMessageListenerContainer.receiveAndExecute(AbstractPollingMessageListenerContainer.java:263)
  at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.invokeListener(DefaultMessageListenerContainer.java:1058)
  at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.executeOngoingLoop(DefaultMessageListenerContainer.java:1050)
  at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.run(DefaultMessageListenerContainer.java:947)
  at java.lang.Thread.run(Thread.java:724)
Geert
    cdovholukAnswer
    Jun 30, 2014 1:35 PM UTC
    I think this means the Action the given expression rule attempted to execute is not meant for the asset/device which actually triggered the expression rule.  Take a look at your expression rules that call "ExecuteAction" (in the then/else sections) and make sure that the Action they are invoking has the same models declared as the expression rule.
    Hope that helps
    cdovholuk5-Regular MemberAnswer
    Hope that helps
    Jul 1, 2014 11:29 AM UTC
    Yes, that was it.
    Once I knew what to look for (= how to interpret the error message), finding the cause was easy.
    Thanks.
