Dec 5, 2018 11:11 AM UTC
error in licensing thingworx
I am using ThingWorx 8.3.1.
ThingWorx was working fine on my windows 10 system as well as a cloud based windows server, while suddenly the license in the "ThingworxPlatform" folder changed from "successful_license_capability_response" to "ignored_license_capability_response" on both these windows systems.
Below is my application log.
2018-12-05 16:06:04.507+0530 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: main] Subsystem LicensingSubsystem is starting
2018-12-05 16:06:04.507+0530 [L: INFO] [O: c.t.s.s.Subsystem] [I: ] [U: SuperUser] [S: ] [T: main] Starting Subsystem [LicensingSubsystem]
2018-12-05 16:06:40.132+0530 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: main] Unable to process capability response because Storage anchor break found.
2018-12-05 16:07:12.311+0530 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: main] Unable to process capability response because Storage anchor break found.
2018-12-05 16:07:44.817+0530 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: main] Unable to process capability response because Storage anchor break found.
2018-12-05 16:08:17.765+0530 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: main] Unable to process capability response because Storage anchor break found.
2018-12-05 16:08:17.768+0530 [L: ERROR] [O: c.t.s.s.l.LicensingStateMachine] [I: ] [U: SuperUser] [S: ] [T: main] Unable to fetch license file with device id XXXX
2018-12-05 16:08:17.806+0530 [L: ERROR] [O: c.t.s.s.l.LicenseFetcher] [I: ] [U: SuperUser] [S: ] [T: main] Unable to process capability response because Storage anchor break found.
2018-12-05 16:08:17.817+0530 [L: INFO] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: main] Unable to read trial license file. Attempting to load as Paid license
2018-12-05 16:08:17.847+0530 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: main] [message: Storage anchor break found.]
2018-12-05 16:08:17.847+0530 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: main] ====================================================================
2018-12-05 16:08:17.847+0530 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: main] License file missing. It's expected at path : C:\ThingworxPlatform\license.bin
2018-12-05 16:08:17.847+0530 [L: WARN] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: main] Shutting down the Platform.
What could be the possible reason?
I have tried re-downloading the license from the license management portal and placing it in the ThingworxPlatform folder by renaming it as "license_capability_response".
However, the same error occurs.
Thanks.
slangleyAnswer
Support
Dec 14, 2018 7:06 PM UTC
Hi @asn.
The solution to the final licensing issue was to create a service account (Windows) with Administrator rights and reconfigure the Tomcat service to run under this account.
For the original issue, it would be helpful if you would mark the appropriate response as the Accepted Solution for the benefit of others who may experience similar issues.
--Sharon
raluca_edu
Dec 5, 2018 12:02 PM UTC
Dec 5, 2018 12:08 PM UTC
Hi @raluca_edu,
As I am working in a secure restricted environment, I do not have the permissions to create a new user as explained in the article you suggested. Is there any other way around this?
raluca_edu
Dec 5, 2018 12:13 PM UTC
Unfortunately, I don't know another solution, but maybe someone from Community has another solution.
Best regards,
Raluca Edu
