Error in scripts written in services of a thing
Hi
I have a service which have some scripts, but when i execute it i get this error
"Wrapped org.json.JSONException: JSONObject["dataShape"] not found. Cause: JSONObject["dataShape"] not found."
I cant find any solution for this in the community.
The script i used is
var params={
      headers :{'Content-Type':'application/json','Accept':'application/json','appkey':'*******'},
      url:'http://************/Thingworx/Things/Logistics/Properties/test',
var Json=Resources["ContentLoaderFunctions"].GetJSON(params);
var Infotable=Resources["InfoTableFunctions"].FromJSON({json:Json});
var testString=Infotable.test;
var result=testString.split("|");
Things["Logistics"].Device_id=result[0];
Things["Logistics"].Flag=result[1];
Things["Logistics"].Theft_flag=result[2];
Things["Logistics"].Temperature=result[3];
Things["Logistics"].Humidity=result[4];
Things["Logistics"].Battery_volt=result[5];
Things["Logistics"].Data=result[6];
Hi
The "FromJSON" method isn't as friendly as it sounds.... see FromJSON() usage
Regards
Ian
