Error Invalid Model
It is my first experience with TW Analytics, I am trying to upload a PMML model version 4.3 from third part.
I created a Provider using the 'AnalyticsServerConnector' but when I upload the model from file using 'Analysis Models' I get the error: 'Invalid Model' and on the ApplicationLog says: 'Unable to deploy model to TW.AnalysisServices.AnalyticsServer.AnalyticsServerConnector'.
Do you know if I might solve that problem or if it is for sure a PMML model problem of compatibility?
Kiund regards,
Marco
nsampatAnswer
@darcudarcu ,
That is correct, I would recommend sending them the PMML of the model you create as a example of the format the partner needs to follow. Their model may be valid, but in a different format than Analytics is expecting.
Neel
20-Turquoise
@nsampat @jgreiner  would either of you guys be able to help here?
@darcudarcu ,
My colleague @posipova brought this thread to my attention.
Can you provide the following information:
What version of ThingWorx Platform Server is being used?
What version of ThingWorx Analytics Server is being used?
Also please note, while PMML 4.3 should work with our application (8.5.1), it needs to be formatted using JPMML 1.3.3.
Have you attempted to upload a dataset into ThingWorx Analytics, then publish to Model using the Connector?
Neel
Hi @nsampat ,
My platform and analytics version is 8.3.1-b441, tomorrow I'll try to see if I get any error publishing a model from data.
Thanks and kind regards,
Marco
