Error launching EMS on Raspberry Pi
Using the example config.json from https://developer.thingworx.com/resources/guides/thingworx-raspberry-pi-quickstart/configure-ems with my hosted instance and generated appKey I get the following error when executing "sudo ./wsems"
[FORCE] 2018-03-26 14:34:17,302 ./wsems: Initializing EMS ....
[FORCE] 2018-03-26 14:34:17,302 main: Using config file /home/pi/thingworx/microserver/etc/config.json
[INFO ] 2018-03-26 14:34:17,302 ./wsems: Creating the WsEms proxy.
[INFO ] 2018-03-26 14:34:17,302 ./wsems: Starting HTTP Server.
[INFO ] 2018-03-26 14:34:17,302 Main: Using custom certificate and private key for HTTP Server
[ERROR] 2018-03-26 14:34:17,303 Main: Failed to get HTTP Server ssl configuration.
[FORCE] 2018-03-26 14:34:17,303 Main: Exiting....
[DEBUG] 2018-03-26 14:34:17,303 jsonConfigurator::~jsonConfigurator: Deleting JSON object
hrajpalAnswer
Try with this:
 "ws_servers": [{
 "host": "pp-1802071422as.devportal.ptc.io",
 "port": 443
 "http_server": {
 "host": "127.0.0.1",
 "port": 8080,
"ssl": false,
"authenticate": false }, "appKey": "990d0f05-c17f-4416-aa07-beefd1e61b50", "logger": { "level": "DEBUG" }, "auto_bind": [{ "name": "PiThing", "gateway": false }], "certificates": { "validate": false, "allow_self_signed":true }, "ws_connection": { "encryption": "ssl", "verbose": true, "msg_timeout": 1000 } }
Seems to be issue with HTTP Server Configuration in config.json file.
Could you please provide me the config.json file so that i can review at my end and see if there is something incorrect in the file?
Himesh Rajpal
eifinger1-VisitorAuthor
as I said it's the sample config:
 "ws_servers": [{
 "port": 443
 "http_server": {
 "port": 8080
 "logger": {
 "level": "DEBUG"
 "auto_bind": [{
 "name": "PiThing",
 "gateway": false
 "certificates": {
 "validate": false,
 "ws_connection": {
 "verbose": true,
 "msg_timeout": 1000
hrajpal5-Regular MemberAnswer
Try with this:
 "ws_servers": [{
 "port": 443
 "http_server": {
 "port": 8080,
"ssl": false,
Emeritus
Hi @eifinger
Just wanted to follow up to see if your question has been answered.  If so, please indicate Accepted Solution for the benefit of all of our Community users.  If not, please let us know your current status.
Thanks!
Leigh
