error message when trying to execute service for getting logged values of property
I have a thing named MVP_1 when i try to execute and get the logged values of property using service "Query named property" it is showing an error saying:
"Unable to Invoke Service QueryNamedPropertyHistory on MVP1_1 : com.thingworx.common.exceptions.DataAccessException: [2,003] Transaction failed."
please provide me actual error
Support
Hi @sarathi.
Does this article apply to your situation?
--Sharon
Support
Hi @sarathi.
If you have found a solution to your problem, please post it here and mark it as the Accepted Solution for the benefit of others on the community.
--Sharon
raluca_edu
We need to see the Error.log and Tomcat logs, could you help with that?
These are necessary to see why this error is happening.
Raluca Edu
