Error: No open connections were available on endpoint
I'm using the Java SDK to send event to Thingworx platform. Checking the application log I found the error :
"Could NOT send response for request 12 on /Things/DeviceTestThing/Services/ProcessRemoteEvents/ [java.lang.Exception: No open connections were available on endpoint 11]"
How to avoid such error ?
Sean
Hello seanccc,
Thank you for reaching out on the ThingWorx Developer Community.
I have not seen this issue firsthand previously. Would it be possible for you to share the complete set of logs that contain reproduction for this issue?
Tyler Misner
ThingWorx Technical Support Engineer
