Error occurred while accessing the data provider
When i tried to delete datatable thing, this error is coming - "com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]"
In Application Log, I can see - "Error in writing to Data Table for Feature : twx_composer, Product: THINGWORX_FOUNDATION Error : Unable to store license usage data in data table due to error:Unable to fetch license usage data from data table due to error:com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]"
how to solve this!!
Hi @AP_9587236
I would suggest that you enable stack tracing as per https://www.ptc.com/en/support/article/CS227712 and reproduce the error.
You should have a bit more details on the error in the errorLog.log file (not ApplicationLog.log)
Hope this helps
Christophe
Support
Hi @AP_9587236.
If you found the previous response helpful, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
