Error occurred while validating HTTP header: cookie
I am getting the below error continuously in application log. I am using thingworx version 7.1.2-b50.
We are getting serious performance issues in production. Is this error causing the problem.
Pai Chung​
Aanjan Ravi​
AanjanAnswer
Raju, the error you're getting is related to the browser cookie not validating correctly on our regex. The validation.properties (under ThingworxStorage/esapi) has a section called 'Validator.HTTPHeaderValue_cookie' where you can add extra characters to allow them through.
With that being said, it should not cause any performance issues per se, as this only affects logging.
Aanjan5-Regular MemberAnswer
rk-311-VisitorAuthor
I got it. So can we do anything that improves the performance.
