"Error occurred while validating HTTP header: cookie" in Application logs
Hi @Aanjan,
I have updated the property "Validator.HTTPCookieValue=^[a-zA-Z0-9-\\\/+=_%;\.| ]*$" and my cookie id was "JSESSIONID=5D443A9AACEABC3C44B7C4883B142D26". The Id seems to match the regex i had checked, but i can still see "Error occurred while validating HTTP header: cookie" in the logs.
Based on  this article, i had changed the platform.settings file as below,
"PlatformSettingsConfig": {
		"BasicSettings": {
			"HTTPRequestHeaderMaxLength": 10000,
			"HTTPRequestParameterMaxLength": 10000
	"PersistenceProviderPackageConfigs": {
		"PostgresPersistenceProviderPackage": {
			"ConnectionInformation": {
				"jdbcUrl": <jdbc:postgresql://postgresql URL/thingworx>,
				"password": "password",
				"username": "twadmin",
				"maxPoolSize": "15000",
				"minPoolSize": "500"
But the issue persists. Please advice.
Thanks and Regards
Saran
raluca_edu
Hi Saran,
Please check also Tomcat logs, it might be some detailed error to give more info.
Raluca Edu
Hi @raluca_edu,
Thanks for your reply. I had checked the catalina logs. There were no error logs recorded in Catalina.out when the message came in the Application logs.
Saran
