Error Scheduler Timeout
Hi All,
need your Help I Run Scheduler for 3 services and i got an error Timeout
(error executing service. Message ::Execution of Script terminated after : 127 seconds. Timeout configured for 120 seconds.)
Regards;
PaiChungAnswer
22-Sapphire I
In platform-settings.json you can set the script timeout, since you have a long running service, I recommend increasing that number.
I do recommend you are careful not to have services run too long, so that you don't run into situations where the service hasn't finished yet and you invoke it again.
PaiChung22-Sapphire IAnswer
22-Sapphire I
could you please clarify from where I can change
Support
Hi @Islam_Amer.
Is your question in reference to the timeout setting?  If so, here's an example:
    "PlatformSettingsConfig": {
        "BasicSettings": {
            "Storage": "C:\\ThingworxStorage",
            "ScriptTimeout": 500
--Sharon
Support
Hi @Islam_Amer.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others in the community with the same question.
--Sharon
