ERROR - series cleanup error: TypeError: Cannot read property 'hide' of null
At every mashup change from menu I get the log above on the browser logs
I read old topics and seems was related to a google map extension, but seems not be the case (I removed also google map extension)
The pages are opened correctly, I have no errors on thingworx script or application logs
Sometimes the property name is not 'hide' but a property used on the pages, got from a data entity
It this something known ?
I have thingworx 8.5.3 cloud hosted
slangleyAnswer
Support
Hi @iguerra.
ThingWorx 9.0, which contains a fix for this issue, has been released and is available for download here.
If you feel your question has now been answered, please mark the appropriate reply as the Accepted Solution for the benefit of others in the community.
--Sharon
Support
Hi @iguerra.
Since this is a hosted implementation, we will need to open a case for further investigation.  With your approval, I'll be happy to do so on your behalf.
--Sharon
iguerra16-PearlAuthor
Yes Thanks
Kind Regards
Support
For others on the community, this issue has been reported to R&D and accepted as a bug.  It is targeted for fix in the 9.0 release.
--Sharon
