Error to import New Dataset on analystics builder
When I am trying to import a new dataset  I am getting the error message "ERROR: column "c7" specified more than once",  but there is nothing with the same value in any place.
What can cause this error?
Hi
Is it possible for you to upload the dataset.csv file and the configuration json file ?
We would need that to investigate.
Thank you
Kind regards
Christophe
psoares1-VisitorAuthor
Follow the file below.
Zip.zip - Google Drive
Hi
Thank you for that.
The field Weight_Rate_Filling_Silo1 is defined twice int he json file and there are 2 columns with this name in the csv.
I am guessing this is a typo and you meant to have Weight_Rate_Filling_Silo1 and Weight_Rate_Filling_Silo2.
In any case the field name should be unique.
I can successfully create the dataset when using Weight_Rate_Filling_Silo1 and Weight_Rate_Filling_Silo2.
Could you try with this modification and see if that works also for you ?
Thank you
Kind regards
Christophe
