ERROR - TW.Runtime.Workspace.Mashups.getWidget exception loading widget
Hi all,
I'm trying to create new Thingworx Widget using Apache echarts. I have created simple chart and imported into Thingworx. I'm able to see widget in Composer but when I try to see chart in runtime I'm getting below error :
17:54:40 ERROR - TW.Runtime.Workspace.Mashups.getWidget exception loading widget {
 message: simplechartdoesn't exist
I checked JAVA OPTIONS everything looks fine.
Thingworx Version : 9.2 ( Fresh Instance)
Could any one help me to solve this issue.
VR
@Velkumar
Try clearing browser and tomcat cache and see if it fixes the issue.
Sachin
Velkumar19-TanzaniteAuthor
@SachinSharma Tried this method. Still no luck !
@Velkumar
Article - CS345409
Error - 'TW.Runtime.Workspace.Mashups.getWidget exception loading widget' is seen on loading mashup with widgets imported as extension
https://www.ptc.com/en/support/article/CS345409
Check java path in tomcat properties
Article - CS246176
ThingWorx Widget is not displayed causing "ERROR - TW.Runtime.Workspace.Mashups.getWidget exception loading widget"
https://www.ptc.com/en/support/article/CS246176
Just a few other items to check.
Here are a few things you can check:
  • Make sure that the widget constructor name is the same for both the IDE and Runtime versions; if in your IDE file your extension is defined as
    TW.IDE.Widgets.simplechart = function () { ... }
    It should have the same name in the runtime file:
    TW.Runtime.Widgets.simplechart = function () { ... }
  • Make sure that there isn't something that prevents the combined extensions file from being evaluated completely. For example, a syntax error in any widget will prevent the extensions from loading at runtime, or an error thrown by a global statement could cause a part of the extension widgets to not load. You should use the browser inspector, rather than the Thingworx logs, to look into this.
