Error: Unable To Convert From java.lang.String to INTEGER
Hello all,
When I try to create "INTEGER" property using extension it throwing error as "Unable To Convert From java.lang.String to INTEGER"
Below is my code:
String propertyname = "TEST";
String type = "INTEGER";
JSONObject remoteBindingAspects = new JSONObject();
thingname.AddPropertyDefinition(propertyname, "", type, "", "", false, true, false, "VALUE", (double) 0, false, "", (int) 3, "VALUE", (double) 0, "", remoteBindingAspects);
Hi @Velkumar you need to ensure that you are working with ThingWorx BaseTypes, if you are looking to define a property of type Integer, it will be BaseTypes.INTEGER, e.g.
FieldDefinition Field1 = new FieldDefinition("Field1", BaseTypes.INTEGER);
Velkumar19-TanzaniteAuthor
Hello @supandey,
In our case datatype changes dynamically, how to overcome that.
Velkumar R
Sorry i am not really sure what do you mean with datatype changes dynamically. If this is part of the infotable or datashape you can adapt that when creating them in runtime.
