Sep 25, 2019 9:52 PM UTC
Error using Resources["EntityServices"].CloneThing(params)
I have a simple service to clone an existing thing. I use Resources["EntityServices"].CloneThing and I got the following error:
JavaException: java.lang.Exception: Unable To Convert From org.json.JSONObject to INFOTABLE
When I duplicate the Thing manually in the Composer there is not problem I can duplicate the thing.
Could you please give some advice?
Freddy
Support
Sep 26, 2019 1:28 AM UTC
 Can you please check the schema of params?
 It should be like the following:
var params = {
	name: "clone_target_thing" /* STRING */,
	description: "Description of clone" /* STRING */,
	sourceThingName: "clone_source_thing" /* THINGNAME */,
	tags: [{
 	"vocabulary" : "Test",
 "vocabularyTerm" : "CloneThingSnippet"
 }] /* TAGS */
Resources["EntityServices"].CloneThing(params);
fkuong1-VisitorAuthor
Sep 26, 2019 12:53 PM UTC
Hi Charles,
My schema for params is correct, in my case description and Tags are undefined.
Freddy
Support
Oct 14, 2019 3:25 AM UTC
Hi, Freddy
Could you please send me the full code of your service, both the ApplicationLog.log and ScriptLog.log when you can reproduce the error message?
* The logs are located in <Thingworx Path>\ThingworxStorage\logs
Charles
