Error when I create database extension
I was wondering how to create metadata.xml when I created the database extension. How to create the following through the eclipse xml file. Xml file is through what kind of process to get. I have Oracle11 to expand the package, I would like to create a mysql extension package based on it myself I do not know what to do?
<Entities>
    <ExtensionPackages>
        <ExtensionPackage name="MYSQL_ExtensionPackage"
                      description="My SQL JDBC Extension"
                      vendor="ThingWorx Customer Service"
                      packageVersion="1.0"
                      minimumThingWorxVersion="4.0.0">
            <JarResources>
                <FileResource type="JAR" file="mysql-connector-java-5.1.22.jar" description="MySQL JDBC JAR" />
            </JarResources>
        </ExtensionPackage>
    </ExtensionPackages>
    <ThingTemplates>
        <ThingTemplate baseThingTemplate="Database" description="MySQL Server" documentationContent="" effectiveThingPackage="" homeMashup="" lastModifiedDate="2015-11-28T11:40:35.355-05:00" name="MySqlServer" tags="" thingPackage="">
            <ThingShape description="" documentationContent="" lastModifiedDate="2015-11-28T11:40:35.355-05:00" name="" tags="">
                <PropertyDefinitions/>
                <ServiceDefinitions/>
                <EventDefinitions/>
                <ServiceImplementations/>
                <ServiceMappings/>
                <Subscriptions/>
            </ThingShape>
            <ImplementedShapes/>
            <ConfigurationTables>
                <ConfigurationTable description="" isMultiRow="false" name="ConnectionInfo">
                    <DataShape>
                        <FieldDefinitions>
                            <FieldDefinition aspect.defaultValue="5.0" baseType="NUMBER" description="Maximum number of connections in the pool" name="maxConnections" ordinal="0"/>
                            <FieldDefinition aspect.defaultValue="jdbc" baseType="STRING" description="jDBCConnectionURL" name="jDBCConnectionURL" ordinal="0"/>
                            <FieldDefinition aspect.defaultValue="SELECT NOW()" baseType="STRING" description="Connection validation string" name="connectionValidationString" ordinal="0"/>
                            <FieldDefinition aspect.defaultValue="com.yourdatabase.yourDriver" baseType="STRING" description="jDBCDriverClass" name="jDBCDriverClass" ordinal="0"/>
                            <FieldDefinition baseType="STRING" description="Database user name" name="userName" ordinal="0"/>
                            <FieldDefinition baseType="PASSWORD" description="Database password" name="password" ordinal="0"/>
                        </FieldDefinitions>
                    </DataShape>
                    <Rows>
                        <Row>
                            <jDBCConnectionURL><![CDATA[jdbc:mysql://localhost:3306/demo]]></jDBCConnectionURL>
                            <maxConnections>100.0</maxConnections>
                            <connectionValidationString><![CDATA[SELECT NOW()]]></connectionValidationString>
                            <jDBCDriverClass><![CDATA[com.mysql.jdbc.Driver]]></jDBCDriverClass>
                            <userName />
                            <password />
                        </Row>
                    </Rows>
                </ConfigurationTable>
                <ConfigurationTable description="" isMultiRow="false" name="ConnectionMonitoring">
                    <DataShape>
                        <FieldDefinitions>
                            <FieldDefinition aspect.defaultValue="1.0" baseType="NUMBER" description="Number of retries" name="numberOfRetries" ordinal="0"/>
                            <FieldDefinition aspect.defaultValue="2000.0" baseType="NUMBER" description="Retry delay in milliseconds" name="retryDelay" ordinal="0"/>
                            <FieldDefinition aspect.defaultValue="false" baseType="BOOLEAN" description="Enable connection monitoring" name="enableMonitor" ordinal="0"/>
                            <FieldDefinition aspect.defaultValue="30000.0" baseType="NUMBER" description="Monitor rate in milliseconds" name="connectionMonitorRate" ordinal="0"/>
                        </FieldDefinitions>
                    </DataShape>
                    <Rows>
                        <Row>
                            <numberOfRetries>1.0</numberOfRetries>
                            <retryDelay>2000.0</retryDelay>
                            <enableMonitor>false</enableMonitor>
                            <connectionMonitorRate>3000.0</connectionMonitorRate>
                        </Row>
                    </Rows>
            </ConfigurationTables>
            <avatar/>
            <DesignTimePermissions>
                <Create/>
                <Read/>
                <Update/>
                <Delete/>
                <Metadata/>
            </DesignTimePermissions>
            <RunTimePermissions/>
            <InstanceDesignTimePermissions>
                <Create/>
                <Read/>
                <Update/>
                <Delete/>
                <Metadata/>
            </InstanceDesignTimePermissions>
            <InstanceRunTimePermissions/>
        </ThingTemplate>
    </ThingTemplates>
</Entities>
    ankiguptaAnswer
    Hi
    Is there any specific reason to use ecipse to create the extension. Database extensions can be simply created using the following extension available on the marketplace ThingWorx IoT Marketplace jdbc-connector-extension
    And here are some already available relational Database extensions for download ThingWorx IoT Marketplace Relational-databases-connectors
    I hope it helps.
    ankigupta5-Regular MemberAnswer
    Hi
    I hope it helps.
