Error while connecting Cassandra Database thing
I am trying to create Cassandra DB Thing but it is not getting connected and shows below error in logs,
 "ERROR starting: JDBC Driver Class Not Found: org.apache.cassandra.cql.jdbc.CassandraDriver".
I have created Cassandra persistence provider and even Cassandra DB is installed and running fine on server.
Please advise.
Anita
22-Sapphire I
Just to verify, you installed the Cassandra DB extension?
asasane1-VisitorAuthor
Hi PaiChung
You are right, i don't have Cassandra DB extension and not able to find it on Marketplace.
Please help me with the link or extension.
22-Sapphire I
I believe this is not on the marketplace and I believe you need to specifically request this.
What is your use case that you would need Cassandra?
