Error while running luaScriptResources
Hi, i am trying to connect my Pi to TW and after i got to the 10th step on the Guide I got this error while running sudo ./luaScriptResources
INFO ] 2019-06-03 19:16:00,37 PiThing: MicroServer is now available.
[INFO ] 2019-06-03 19:16:00,37 PiThing: MicroServer is online.
[INFO ] 2019-06-03 19:16:00,37 PiThing: Successfully registered PiThing with MicroServer.
[INFO ] 2019-06-03 19:16:00,200 PiThing: Error occured while accessing EMS. Checking isConnected.
[INFO ] 2019-06-03 19:16:00,205 PiThing: EMS is available: true, online: true
[INFO ] 2019-06-03 19:16:00,205 PiThing: Attempting to GetPropertySubscriptions from server failed. code: 500, result:
i am running wsems and luaScript at the same time
I am attaching here the PiTemplate.lua, config.json and config.lua
 Where did you get these sample files? They do not match the ones in the guide on developer.thingworx.com
scripts.PiThing = {
file = "thing.lua",
template = "PiTemplate",
identifier = "PiThing",
scanRate = 1000,
taskRate = 30000
Try removing the the `identifier` line from config.lua
You may be looking at documentation that is not current. These lines should be removed from config.json:
"auto_bind": [{
"name": "PiThing",
"gateway": false
I am not sure that will solve your problem.
Have you tried moving onto the next step and creating a remote Thing in ThingWorx COmposer
gabitudor1-VisitorAuthor
Hi, thank you for the replay!
i tried with both auto_bind and without and it did not work. And yes, i also tried to go further in the Guide but after creating the Remote Thing, it is not connected.
still getting the EMS error
scripts.PiThing = {
file = "thing.lua",
scanRate = 1000,
taskRate = 30000
