Nov 23, 2016 7:43 AM UTC
Errors while trying to connect raspberrypi to thingworx cloud
am a beginner to thingworx cloud, i followed the quick start step by step guide to connect raspberrypi ,when i executed
sudo ./wsems
[INFO ] 2016-11-23 12:17:49,846 ./wsems: Using config file: /home/pi/microserver/etc/config.json
[FORCE] 2016-11-23 12:17:49,846 ./wsems: Starting up ....
[FORCE] 2016-11-23 12:17:49,846 ./wsems: Initializing EMS ....
[FORCE] 2016-11-23 12:17:49,846 main: Using config file /home/pi/microserver/etc/config.json
[INFO ] 2016-11-23 12:17:49,846 ./wsems: Creating the WsEms proxy.
[INFO ] 2016-11-23 12:17:49,846 ./wsems: Starting HTTP Server.
[INFO ] 2016-11-23 12:17:49,847 ./wsems: Initializing the ThingWorx REST interface.
[FORCE] 2016-11-23 12:17:49,847 httpServer: starting http server port=8080
[DEBUG] 2016-11-23 12:17:49,847 SDK: Server socket error: Address already in use [127.0.0.1:8080]
[ERROR] 2016-11-23 12:17:49,847 httpserver: Server socket error: Address already in use [127.0.0.1:8080]
[DEBUG] 2016-11-23 12:17:49,848 SDK: twTlsClient_Create: Initializing TL8080, trying next port.
[ERROR] 2016-11-23 12:17:49,848 httpServer: twTlsClient_Create: Initializing TL8080, trying next port.
[ERROR] 2016-11-23 12:17:49,848 httpserver: Server socket error: Address already in use [127.0.0.1:8081]
[ERROR] 2016-11-23 12:17:49,848 httpServer: unable to bind http server to port=8081, trying next port.
[ERROR] 2016-11-23 12:17:49,848 httpserver: Server socket error: Address already in use [127.0.0.1:8082]
[ERROR] 2016-11-23 12:17:49,848 httpServer: unable to bind http server to port=8082, trying next port.
[DEBUG] 2016-11-23 12:17:49,848 SDK: twApi_Initialize: Websocket Established after 0 tries
[ERROR] 2016-11-23 12:17:49,848 httpserver: Server socket error: Address already in use [127.0.0.1:8083]
[ERROR] 2016-11-23 12:17:49,848 httpServer: unable to bind http server to port=8083, trying next port.
[DEBUG] 2016-11-23 12:17:49,849 SDK: subscribedPropsMgr_Initialize: Initializing subscribed properties manager
[ERROR] 2016-11-23 12:17:49,849 httpserver: Server socket error: Address already in use [127.0.0.1:8084]
[ERROR] 2016-11-23 12:17:49,849 httpServer: unable to bind http server to port=8084, trying next port.
[DEBUG] 2016-11-23 12:17:49,849 jsonConfigurator::getJsonEntity:
[ERROR] 2016-11-23 12:17:49,849 httpserver: Server socket error: Address already in use [127.0.0.1:8085]
[ERROR] 2016-11-23 12:17:49,850 httpServer: unable to bind http ser not found
[DEBUG] 2016-11-23 12:17:49,850 jsonConfigurator::getJsonEntity: unable to bind http ser not found
52.199.115.146:80-->[ERROR] 2016-11-23 12:17:49,850 httpserver: Server socket error: Address already in use [127.0.0.1:8086]
[ERROR] 2016-11-23 12:17:49,850 httpServer: unable to bind http server to port=8086, trying next port.
[ERROR] 2016-11-23 12:17:49,850 httpserver: Server socket error: Address already in use [127.0.0.1:8087]
[ERROR] 2016-11-23 12:17:49,851 httpServer: unable to bind http server to port=8087, trying next port.
[ERROR] 2016-11-23 12:17:49,851 httpserver: Server socket error: Address already in use [127.0.0.1:8088]
[ERROR] 2016-11-23 12:17:49,851 httpServer: unable to bind http server to port=8088, trying next port.
[DEBUG] 2016-11-23 12:17:49,851 httpServer: http server bound to port=8089.
[DEBUG] 2016-11-23 12:17:49,851 jsonConfigurator::getJsonEntity: Parent file not found
[DEBUG] 2016-11-23 12:17:49,852 jsonConfigurator::getJsonEntity: Parent file not found
[INFO ] 2016-11-23 12:17:49,852 wsEmsProxy::initialize: Initialization complete!
[INFO ] 2016-11-23 12:17:49,852 ./wsems: Starting the connection.
[DEBUG] 2016-11-23 12:17:49,852 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2016-11-23 12:17:49,852 SDK: twTlsClient_Connect: Connecting to server
[DEBUG] 2016-11-23 12:17:50,103 SDK: ws_on_headers_complete: Websocket connected!
[AUDIT] 2016-11-23 12:17:50,103 SDK: twWs_Connect: Websocket connected!
[DEBUG] 2016-11-23 12:17:50,103 SDK: twWs_SendMessage: Sent 60 bytes using 1 frames.
[DEBUG] 2016-11-23 12:17:50,395 SDK: twMessage_Delete:  Deleting RESPONSE Message: 1
[DEBUG] 2016-11-23 12:17:50,395 SDK: twMessage_Delete:  Deleting AUTH Message: 1
[DEBUG] 2016-11-23 12:17:50,395 SDK: twWs_SendMessage: Sent 26 bytes using 1 frames.
[DEBUG] 2016-11-23 12:17:50,400 SDK: sendCtlFrame: >>>>> Sending Ping. Msg: 06:47:50
[INFO ] 2016-11-23 12:17:50,401 Main: Succesfully connected.  Saving .booted config file
[DEBUG] 2016-11-23 12:17:50,697 SDK: twMessage_Delete:  Deleting RESPONSE Message: 2
[DEBUG] 2016-11-23 12:17:50,697 SDK: twMessage_Delete:  Deleting BIND Message: 2
[DEBUG] 2016-11-23 12:18:45,416 SDK: sendCtlFrame: >>>>> Sending Ping. Msg: 06:48:45
Here i get the proper output as websocket created and successfully connected as requested in the guide
but after following further steps and executing luaScriptResource i get error while creating new handler as follows
pi@rooman:~/microserver $ sudo ./luaScriptResource
[INFO ] 2016-11-23 12:18:20,139 ./luaScriptResource: Using config file: /home/pi/microserver/etc/config.lua
[FORCE] 2016-11-23 12:18:20,140 ./luaScriptResource: Starting up ....
[INFO ] 2016-11-23 12:18:20,145 ./luaScriptResource: New path is /home/pi/microserver/etc/thingworx/clibs:/home/pi/microserver/etc/custom/clibs:/home/pi/microserver/etc/community/clibs:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
[FORCE] 2016-11-23 12:18:20,184 httpServer: starting http server port=8001
[ERROR] 2016-11-23 12:18:20,194 httpserver: Server socket error: Address already in use [*:8001]
[ERROR] 2016-11-23 12:18:20,194 httpServer: unable to bind http server to port=8001, trying next port.
[ERROR] 2016-11-23 12:18:20,195 httpServer: unable to bind http server to any port from 8001 to 8001.
[INFO ] 2016-11-23 12:18:20,265 thingworx.shape: Creating a new shape.
[INFO ] 2016-11-23 12:18:20,266 PiThing: -- Configuration -------------------------------
[INFO ] 2016-11-23 12:18:20,267 PiThing: scanRate: 60000
[INFO ] 2016-11-23 12:18:20,267 PiThing: scanRateResolution: 500
[INFO ] 2016-11-23 12:18:20,268 PiThing: taskRate: 15000
[INFO ] 2016-11-23 12:18:20,268 PiThing: keepAliveRate: 60000
[INFO ] 2016-11-23 12:18:20,269 PiThing: requestTimeout: 15000
[INFO ] 2016-11-23 12:18:20,269 PiThing: registerRate: 43200000
[INFO ] 2016-11-23 12:18:20,270 PiThing: register: true
[INFO ] 2016-11-23 12:18:20,270 PiThing: getPropertySubscriptionOnReconnect: false
[INFO ] 2016-11-23 12:18:20,271 PiThing: maxConcurrentPropertyUpdates: 100
[INFO ] 2016-11-23 12:18:20,272 PiThing: defaultPushType: VALUE
[INFO ] 2016-11-23 12:18:20,272 PiThing: useShapes: true
[INFO ] 2016-11-23 12:18:20,273 PiThing: identifier: Not Specififed
[INFO ] 2016-11-23 12:18:20,273 PiThing: ------------------------------------------------
[INFO ] 2016-11-23 12:18:20,283 thingworx.template: Adding shape 'shapes.metadata' to template 'thingworx.template'
[INFO ] 2016-11-23 12:18:20,283 thingworx.template: Adding shape 'shapes.propsubscribe' to template 'thingworx.template'
[INFO ] 2016-11-23 12:18:20,283 thingworx.template: Creating new templates.PiTemplate named 'PiThing'
[INFO ] 2016-11-23 12:18:20,283 PiThing: -- Initializing properties ---------------------
[INFO ] 2016-11-23 12:18:20,283 PiThing: Initialized property upToDate [baseType: BOOLEAN, pushType: NEVER, handler: nil, value: true]
[INFO ] 2016-11-23 12:18:20,283 PiThing: Initialized property cpu_volt [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0]
[INFO ] 2016-11-23 12:18:20,283 PiThing: Initialized property cpu_temperature [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0]
[INFO ] 2016-11-23 12:18:20,284 PiThing: Initialized property cpu_freq [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0]
[INFO ] 2016-11-23 12:18:20,284 PiThing: ------------------------------------------------
[INFO ] 2016-11-23 12:18:22,251 PiThing: -- Starting script --------------------------
[INFO ] 2016-11-23 12:18:22,251 PiThing: Registering core callback handler
[INFO ] 2016-11-23 12:18:22,251 PiThing: Starting main loop
[INFO ] 2016-11-23 12:18:22,251 PiThing: Calling lifecycle start listeners.
[INFO ] 2016-11-23 12:18:22,251 shapes.propsubscribe: Initialized
[INFO ] 2016-11-23 12:18:22,253 thingworx.handler: Creating a new handler.
[ERROR] 2016-11-23 12:18:52,259 HttpClient::processReq: Timeout while waiting for response from 127.0.0.1.
[ERROR] 2016-11-23 12:18:52,259 luaBindings::httpPost: Error POSTing to HTTP Server at 127.0.0.1/Thingworx/Things/LocalEms/Services/AddEdgeThing
[INFO ] 2016-11-23 12:18:52,260 PiThing: Error occured while accessing EMS. Checking isConnected.
[ERROR] 2016-11-23 12:19:22,265 HttpClient::processReq: Timeout while waiting for response from 127.0.0.1.
[ERROR] 2016-11-23 12:19:22,265 luaBindings::httpGet: Error GETing from HTTP server at 127.0.0.1/Thingworx/Things/LocalEms/Properties/isConnected
[INFO ] 2016-11-23 12:19:22,265 PiThing: EMS is available: false, online: false
[ERROR] 2016-11-23 12:19:52,791 HttpClient::processReq: Timeout while waiting for response from 127.0.0.1.
[ERROR] 2016-11-23 12:19:52,791 luaBindings::httpPost: Error POSTing to HTTP Server at 127.0.0.1/Thingworx/Things/LocalEms/Services/AddEdgeThing
[INFO ] 2016-11-23 12:19:52,791 PiThing: Error occured while accessing EMS. Checking isConnected.
[ERROR] 2016-11-23 12:20:22,796 HttpClient::processReq: Timeout while waiting for response from 127.0.0.1.
[ERROR] 2016-11-23 12:20:22,796 luaBindings::httpGet: Error GETing from HTTP server at 127.0.0.1/Thingworx/Things/LocalEms/Properties/isConnected
[INFO ] 2016-11-23 12:20:22,796 PiThing: EMS is available: false, online: false
kindly help me to rectify this issue
Nov 23, 2016 2:41 PM UTC
Looks like you need to change the port your EMS is running on... something else on localhost is running on port 8085, according to the above error.
mkk1-VisitorAuthor
Nov 24, 2016 4:25 AM UTC
Thank you for your time.
I changed the port and tried and it worked,Thank you
Now i can see my device is connected in  composer.but when i bind the thing properties on manage bindings its not loading the properties.its shows
"Error browsing properties. Be sure the remote device/server is connected and configured properly"
But in properties i can see
Isconnected value as true and lastconnection value as  time
can you kindly help me on this too?
Nov 28, 2016 2:47 PM UTC
Are you using the LSR? Is this running on localhost also? Is it configured properly?
