ES6 syntax error: 'operator is only available in ES6 (use 'esversion: 6')'
My platform version is ThingWorx 8.5.4-b222
In service I try to use spread operator:
const result = [...arr1, ...arr2];
 But I receive error:
'spread operator' is only avaiable in ES6 (use 'esversion: 6')
How can I fix it?
Thanks in advance.
raluca_edu
I don't think spread operator is supported, Thingworx 8.5.x is using Rhino Javascript Engine 1.7.11.
See here a support table:
https://mozilla.github.io/rhino/compat/engines.html
Hope it helps,
Raluca Edu
raluca_edu
Could you provide a code example to reproduce it?
Raluca Edu
hi,
yes, sure:
const arr1 = [0, 1, 2];
const arr2 = [3, 4, 5];
let result = [...arr1, ...arr2];
raluca_edu
Hope it helps,
Raluca Edu
