Event and mail generation
Hi All,
I have two properties A and B, now I want to generate an event when property A value is less than B value. Also I need to send an email when this condition happens. How I can achieve this? I am using ThingWorx 8.3 version.
PaiChungAnswer
22-Sapphire I
You can do this by using the DataChange event.
You'd have to probably monitor the change in both the A and B values.
Also please be aware, if these values change often, then you might be sending a lot of notifications.
So you might want to either create some logic to prevent that, or resolve this into a Boolean Property that you set to True or False this way you can provide a 'lock in' and then send notification on the true/false toggle
PaiChung22-Sapphire IAnswer
22-Sapphire I
Thank you for the reply
