Export edited grid column along with all data from grid
Hi Developers,
I have a requirement to take 3 different data sources (1 label and 2 grids) and export an excel from it.
I am not able to get csv with edited column along with its other original entire grid columns.
Please provide service to achieve this, if someone has any.
Yes, it's possible.
1. Create a datashape with all required fields
2. Read all the data from infotable
3. Insert into new info table with new data shape.
write a custom server.
  • inputs [3]
  • compile all the 3 input data into single infotable
  • output as infotable with data export widget or Write CSV data into repository
Hi @Sathishkumar_C ,
I referred to solution available on  https://www.ptc.com/en/support/article/CS237109.
I took the code and used AddRow snippet, but I want to merge data of both infotable in one row.
Is it possible?
Yes, it's possible.
