3-Newcomer
Feb 3, 2025 6:41 AM UTC
Export/Import migration on version 9.3.19 of Thingworx Foundation.
I am using ThingWorx Platform Release 9.3 and DatecodeF000
We have installed Thingworx Foundation 9.3.19 on a test server to validate the export and import process of existing projects from the previous version. However, we're facing issues with importing certain entities. Specifically, the number of entities successfully imported (e.g., Thing templates) does not match the total number initially exported. Additionally, some of the imported entities are not visible in the UI.
Few extensions not imported due to digest match even though recommended java version is installed.
Here are the errors that I faced
Unable to process import: Thing PTC.SCA.SCO.DefaultOperatorAdvisorFileRepository has an invalid thing template [PTC.SCA.SCO.OperatorAdvisorFileRepositoryThingTemplate]
Unable to Invoke Service ImportSourceControlledEntities on SourceControlFunctions : Import Failed: Thing PTC.SCA.SCO.DefaultOperatorAdvisorFileRepository has an invalid thing template [PTC.SCA.SCO.OperatorAdvisorFileRepositoryThingTemplate]
OA_OperatorAdvisor-extension:8.5.2 C:\PROGRA~2\THINGW~1\ThingworxStorage\extensions\temp\OA_OperatorAdvisor-extension_e5e3ede1-bd39-4e74-b4d3-3a2139e563ef\OA_OperatorAdvisor-extension.zip signed extension file does not match digests
    3-Newcomer
    Feb 3, 2025 11:18 AM UTC
    For the extension signed with Java 8 issue, I already have the recommended java version (11.0.16 or lower, 11.0.16 in my case). installed.
    Support
    Feb 20, 2025 9:59 PM UTC
    Hi @SK_11297561
    From your last response, I'm unable to determine if you received the answer you needed.  If so, please mark the response from Rocko as the Accepted Solution.  If you still have issues please let us know so we can continue to provide support.
    --Sharon
