May 12, 2026 4:46 PM UTC
Export with instance level permissions
I am creating an extension, and would to include instance level permissions - the organization and user groups exist in all environments, but this detail is not included in the xml during export.
I attempted to manually add this detail in the xml, which imported without complaint but the permissions appeared to be ignored.
Is there a better option to include permissions when creating an extension, or does this need to be set in the target environment?
nmutterAnswer
May 27, 2026 12:12 PM UTC
Can you be a little bit more specific as normally permissions are also exported.
E.g. I have a ThingTemplate with Instance runtime permissions in my extension. If I export that to source control, the .xml will have the configured permissions inside (which is also applied)
Maybe also how do you export the entitites?
nmutter17-PeridotAnswer
ablyth10-MarbleAuthor
May 27, 2026 2:58 PM UTC
This is working OK for me now - I can’t reproduce the issue and wish I had recorded it - thanks for the response,
