Exporting/importing of data from/to thingworx
  • November 16, 2016
  • 1546 views
Hi Team.
I do export of multiple datatables from thingworx and import into another thingworx system.
While submitting for export, I get a pop up giving me the task Id. Where do I find if that particular task is successful?
In which log level, i can see the status of this task id.
It would be helpful if you provide the answer with the screen shots.
The task status will appear in the Application log, located under Monitoring > Application in the navigation bar at the top-right corner of ThingWorx Composer. The Application log looks like this:
Hope this helps!
