Extension export from Composer
Hi Folks,
Is there any way to export an Extension from Thingworx composer?
I developed a custom widget but lost all the build files and no access to WebApps folder files. How to recover it using composer?
Thanks!
20-Turquoise
The only pieces you can get are what's in your ThingworxStorage\extensions folder found in your installation path on the harddrive.
TanmeyTWX17-PeridotAuthor
I dont have access to ThingworxStorage folder.
Support
Hi @TanmeyTWX.
If the response by @posipova answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for using our community.
--Sharon
