Nov 7, 2024 9:24 AM UTC
extension for converting csv files to parquet fails on Thigworx 9.6 installed on kubernetes
The extension uses the org.apache.parquet library and writes the parquest file to Thingworx repositories. The service works correctly if Thingworx is installed on a Virtual machine. The service fails to write the file to Thingworx repositories if Thingworx is installed on kubernetes containers. In particular the extension fails by going to do a chmod 644 on the file to define the correct privileges. Has anyone had the same problem? Are there any solutions to the problem?
Dimitri
slangleyAnswer
Support
Mar 4, 2025 9:33 PM UTC
Hi @dbologna
Per the case you opened, you were able to develop a new extension for resolving your issues.  If you would like to share more information regarding your fix, please feel free to post it here.
--Sharon
Nov 7, 2024 1:36 PM UTC
This seems specific to how the ThingWorxStorage PVC is mounted in the PTC Cloud. We are aware that you have opened a case and are currently investigating.
18-Opal
Nov 7, 2024 1:45 PM UTC
Hello Dimitri,
Just a guess -- some k8s implementations (notably Openshift) do not grant container user root permissions. I guess you mount /ThingworxStorage as a Persistent Volume. In this case you need to specify user IDs explicitly on your pods and volumes, to grant non-root users write access to such mount, as described here.
Also, a pretty obvious tip -- try to log into ThingWorx pod and check permissions on the /ThingworxStorage/repository directory itself.
/ Constantine
slangleyCommunity ManagerAnswer
Support
Hi @dbologna
--Sharon
