11-Garnet
Oct 24, 2022 10:16 AM UTC
Extension Google Map
Hello, I have imported a modified google map widget extension but it does not appear in widgets, I have another modified google map widget extension but with another name, can it be a reason why the extension does not appear?
Oct 26, 2022 4:33 PM UTC
Hello @AC_9552412 ,
Pls check the following article for the same:
https://www.ptc.com/en/support/article/cs188314
Kindly let me know if you have any further queries.
Regards
Bhawna
11-Garnet
Oct 28, 2022 9:12 AM UTC
hello, it is not the same problem, the google map extension that I have imported does not appear in the widget box
Support
Oct 28, 2022 12:18 PM UTC
Hi @AC_9552412
This is usually a caching problem.  Try clearing your browser and restarting ThingWorx.
--Sharon
