FAIL - Application at context path [/Thingworx] could not be started
Hi!
Issue:
Experiencing this error upon starting Thingworx on Tomcat Manager "FAIL - Application at context path [/Thingworx] could not be started"
Please see attached file for the logs.
Actions taken:
-version checking
-adding thingworx license
-adding thingworx in system variables
-added folder full control access
-edited WEB-INF from WEBINF
-restarted Tomcat 8.5
With this, I'm still not able to start Thingworx on my local machine. Did I missed on any steps? Appreciate your help. Thanks!
Currently doing:
-reinstall Tomcat 8.5 from 32 bit to 64 bit
This is RESOLVED.
I did a fresh installation and the significant correction was reinstalling Tomcat from Tomcat 8.5 32 bit to Tomcat 8.0 64 bit.
posipovaAnswer
20-Turquoise
Seems that you have a 32 bit version of Tomcat (note how the path is x86). Please uninstall your tomcat, download a 64 bit version, and install from there.
Angelica Lei Quebec Can you please check this path - -Djava.library.path=C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5\webapps\Thingworx\WEBINF\extensions
I think this would be with WEB-INF instead if WEBINF .Can you please update this path and try restarting tomcat again .
Thanks ,
Mukul Narang
aquebec1-VisitorAuthor
Mukul Narang​ Thank you for replying.
I already changed WEBINF to WEB-INF and restarted Tomcat. But still same error occurs.
Will update the attached log files.
Thanks again.
Angelica Lei Quebec​ - Can you also share application logs for this .You can get this from ThingWorxStorage -> logs -> ApplicationLog
Mukul Narang
