FAIL - Application at context path /Thingworx could not be started
I am trying to upgrade to Thingworx 5.0 SP1 from Thingworx 5.0. I undeployed Thingworx on Tomcat and then deployed the 5.0 SP1 WAR file, however I can't start the /Thingworx application. It gives me the error mentioned in the title.
Thank you,
Mike
    Hi Mike,
    Do you have any availability today for a quick call to troubleshoot?
    Have you been able to find the solution - I've run into the very same issue today.
    Bartosz
    I was missing /ThingworxStorage and /ThingworxBackupStorage directories - in case anyone stumbled upon this problem.
    Bartosz
