Failed to create SecurityManager, Failed to load SecretProvider
I am trying to use docker, i followed this tutorial:
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Installation/ThingWorxDockerGuide/thingworx_docker_landing_page.html#
However, I get this error:
 This link does not give info for docker: https://www.ptc.com/en/support/article/CS305796
Does anyone have an idea?
Regards
EDIT: I have the same error as this one: https://www.ptc.com/en/support/article/cs328592
However, I am using the h2 database so there is no docker-compose-h2-clustered folder
Support
Hi @AF_9440574
Did you run through the steps in the first article you mentioned for resolving any config issues?  Did you check for any typos in your script?  What version of ThingWorx are you running?  Did you validate that the PTC support account you are using for licensing is valid?
Have you checked the logs at /ThingworxStorage/logs or <tomcat_home>/logs for possible causes?
--Sharon
