Failed to import a database thing
I have failed to import a database Thing, that is exported from a DEV system, into a QA system. That was failed because of password fields in the XML exported file. What is the best way to migrate changes in a database Thing from a system to another system? Both systems are running the same version 7.4.19-b262
Any suggestion would be greatly appreciated!
My Bests,
Hung Tran
htran-21Answer
Hi @vangne
The suggested solution "binary mode" does not work cause that will lead to lose the existing configuration of these Things on the target system. I've written a small tool that help me migrate changes without losing any configuration.
Sincerely,
Hung Tran
@htran-21 Are you seeing any specific errors in the logs for failed import?
htran-2115-MoonstoneAuthor
Hi @vangne
The error is 406 Not Acceptable.
2019-08-27 03:20:20.484-0500 [L: ERROR] [O: E.c.t.w.Importer] [I: ] [U: tranh] [S: ] [T: http-nio-192.168.230.139-443-exec-32] [message: Conversion Error on Field password : Unable To Convert From com.sun.org.apache.xerces.internal.dom.DeferredElementNSImpl to PASSWORD]
2019-08-27 03:20:20.484-0500 [L: ERROR] [O: E.c.t.w.Importer] [I: ] [U: tranh] [S: ] [T: http-nio-192.168.230.139-443-exec-32] [message: Conversion Error on Field password : Unable To Convert From com.sun.org.apache.xerces.internal.dom.DeferredElementNSImpl to PASSWORD] java.lang.Exception: Conversion Error on Field password : Unable To Convert From com.sun.org.apache.xerces.internal.dom.DeferredElementNSImpl to PASSWORD
	at com.thingworx.types.collections.ValueCollection.fromXMLTypedImport(ValueCollection.java:583)
	at com.thingworx.types.collections.ValueCollectionList.fromXMLTypedImport(ValueCollectionList.java:315)
	at com.thingworx.types.ConfigurationTable.fromXMLImport(ConfigurationTable.java:201)
	at com.thingworx.types.collections.ConfigurationTableCollection.fromXMLImport(ConfigurationTableCollection.java:362)
	at com.thingworx.entities.utils.EntitySerializationUtilities.readConfigurationDataFromXMLImport(EntitySerializationUtilities.java:79)
	at com.thingworx.entities.RootEntity.readRootEntityFromXMLGeneric(RootEntity.java:3827)
	at com.thingworx.entities.RootEntity.readRootEntityFromXMLImport(RootEntity.java:3841)
	at com.thingworx.things.Thing.fromXMLImport(Thing.java:8889)
	at com.thingworx.system.managers.ThingManager.fromXMLImport(ThingManager.java:129)
	at com.thingworx.entities.collections.RootEntityCollection.fromXML(RootEntityCollection.java:454)
	at com.thingworx.contentmanagement.XmlEntityUnmarshaller.getRootEntityCollectionByName(XmlEntityUnmarshaller.java:52)
	at com.thingworx.contentmanagement.Import.parseImportDocument(Import.java:42)
	at com.thingworx.contentmanagement.Import.parseImportDocument(Import.java:23)
	at com.thingworx.webservices.Importer.processImport(Importer.java:311)
	at com.thingworx.webservices.Importer.importFromAttachment(Importer.java:195)
	at com.thingworx.webservices.Importer.service(Importer.java:153)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:292)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240)
	at com.thingworx.security.contenttype.ContentTypeFilter.doFilter(ContentTypeFilter.java:109)
	at com.thingworx.security.filter.ValidationFilter.doFilter(ValidationFilter.java:22)
	at com.thingworx.security.authentication.AuthenticationFilter.propagateRequest(AuthenticationFilter.java:479)
	at com.thingworx.security.authentication.AuthenticationFilter.doFilter(AuthenticationFilter.java:172)
	at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
	at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
	at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
	at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:389)
	at com.thingworx.security.filter.ClickjackFilter.doFilter(ClickjackFilter.java:188)
	at com.thingworx.security.filter.ProhibitIfNotLeaderFilter.doFilter(ProhibitIfNotLeaderFilter.java:120)
	at com.thingworx.security.filter.HttpResponseHeadersFilter.doFilter(HttpResponseHeadersFilter.java:173)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:212)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:94)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:504)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
	at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:620)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:502)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1132)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:684)
	at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1533)
	at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1489)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Unknown Source)
I tried to export the same database thing from both systems into XML files, and compare, the different section is password tag. I did manually merge changes without password tag, and it works. However, that way is a pain.
My Bests,
Hung Tran
@htran-21  Please check this article for more info on this issue.
Vibhuti
