Jan 9, 2024 6:44 AM UTC
Fetching outgoing dependencies, err: Unable To convert org.mozilla.javascript.UniqueTag to INFOTABLE
Trying to fetch the outgoing dependencies of a thing as an infotable  using the GetOutgoingDependencies service in the  PTC.Resource.RelationshipUtilities,  but facing this error :
 Error executing service. Message ::Unable To Convert From org.mozilla.javascript.UniqueTag to INFOTABLE - See Script Error Log for more details.
Here:
var thingName =   "sampleThing"
var mxItems = 10;
var mxDepth = 2;
let params = {
    target: thingName,
    maxItems: mxItems,
    maxDepth: mxDepth
    var relData = Resources["PTC.Resource.RelationshipUtilities"].GetOutgoingDependencies(params);
Arun_CAnswer
Jan 9, 2024 7:11 AM UTC
Hi @AV_10867476 ,
I'm not sure which version of TWX you were using but to find the below code to find outgoing dependencies of a thing and also try to print Ouput in variable of 'result' and make sure that Service Output basetype as 'Infotable'.
var thingName = 'YOURTHINGNAME';
let relData = Things[thingName].GetOutgoingDependencies({
	maxItems: 500 /* NUMBER {"defaultValue":500} */
let result = relData ;// OUTPUT VARIABLE SHOULD BE IN 'result'
Thanks & Regards,
Arun C
Arun_C16-PearlAnswer
Hi @AV_10867476 ,
Thanks & Regards,
Arun C
Jan 9, 2024 9:25 AM UTC
Thanks!
