8-Gravel
Fibonacci series using recursion
I'm attempting to produce a Fibonacci series of initial ten elements utilizing recursion. However, the compiler gives an error. Kindly assist me with tracking down the specific arrangement.
The program is given below:
public class DemoJava {
 int a=0, b=1, c=0, count=10;
 public void fibonacciRecursion(count) {
 if(count>0){
 c = a+b;
 a = b;
 b = c;
 System.out.println(c);
 fibonacciRecursion(count-1);
 public static void main(String args[]){
 System.out.println("This is a Demo Program.");
 System.out.println(a);
 System.out.println(b);
 DemoJava dj = new DemoJava();
 dj.fibonacciRecursion((count-2));
I have also read a couple of resources on the fibonacci series on the wiki, scaler and Quora to understand the topic in a better way. kindly help!
nmillesonAnswer
@sachinbhatt ,
Could you give us a little more context around this issue?  Are you trying to write a ThingWorx extension in Java?  Or are you trying to write a JavaScript service in the Composer?
Nick
nmilleson17-PeridotAnswer
@sachinbhatt ,
Nick
